Hi,
I'm using CCE 2.5 to covert DV avi's to svcd . I got one question:
The guide says:
The Image Quality Priority indicates how many bits will be allocated to complex parts of the picture. It's a value between 0 and 100 and the smaller the value the more bits will be allocated to complex parts. If you think scenes with a low amount of action look bad you should increase this value.
Is it best to leave it at the default setting of 17 or the lower the better quality?? Read that somewhere aswell !
I ussually put it on 7.
I hope someone can help me??
Thanks.![]()
Marhart71
Results 1 to 1 of 1
Help with audio in bar please
By theflame01 in forum AudioReplies: 0Last Post: 30th Apr 2010, 05:21 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2008, 23:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 17:30 -
Black bar problems
By mikeyspiky200 in forum DVD RippingReplies: 3Last Post: 1st Jan 2008, 11:45
