I would like to purchase a vintage Studio Pedestal in order to save a lot of money compared to buying a brand new one, and was wondering how I could go about mounting a modern DSLR or camcorder on one? ITE ones are nice.
This is what I am talking about basically,
http://www.ebay.com/itm/2-ITE-Mathews-Studio-Pedestal-dollies-/281162709227?pt=US_Trip...item41769a78eb
	See that bowl-shaped socket in the top? That's where a fluid head goes. You would have to get one of those as well (couple hundred $ for good one), then you would probably need a click-lock type adapter on that, and then a screw adapter on that (one that fits your cam & the clicklock.
 All that, and you still have a dolly that is only good on a smooth studio floor! All for just ~2k.
 If that is what you want/need, go for it. But if you really just need a top general purpose tripod, you could get one, with fluid head and adapters, all new, for a similar amount of money.
	Google "fluid head 100mm bowl" (assuming it IS 100mm bowl - YMMV) and you'll get a lot of hits.
	You can start here:
 http://www.bhphotovideo.com/c/search?Ns=p_PRICE_2%7c0&ci=3918&N=4028759242+4016833846&srtclk=sort
 Do you think you could ask the ebay seller for the exact measure of the pedestalīs bowl?...if itīs a non standard size or bigger than 100 mm (if you look at heads of that size right there in B&H youīll see that they are far costlier)
 you could have a local machin shop make an adapter plate aout of a circular steel plate and a circle inside with the heads size (the inner edge should be filed to acomodate the headīs angle for a correct fit)
  DSLR or HD camcorderBy rbacevac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 30th Nov 2013, 08:03
  Does anyone know what I could use for for a camcorder mount?By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 22nd Sep 2013, 18:47
  Mix footage from dslr and camcorderBy gerlos in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2013, 06:46
  What shoots better HD video...a HD camcorder or a high end DSLR?By Moontrash in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Sep 2012, 00:47
  Camcorder or DSLR camera reccomendation wantedBy ZombieTrev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 17th May 2012, 10:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
