I have just started downloading movies and encoding them with TMPGEnc, but I have a problem. I am burning them to cd using Roxio 5 and there is a problem with the audio and video going out of synch. When i view them mpg file on the pc they are perflect in synch....
...does anyone have any advice or ideas to help me?
David![]()
David,
I have never really been keen on Rixio, I would download a copy of Nero and try using that. Most people here would be using Nero.
www.nero.com (I think)
Hypnotic_Moose -
Don't let "Video Cd Creator" change the movie, make sure you use a template in TMPGEnc and make a "fully compliant" VCD, then video cd creator will not reprocess the video and cause the problem you have, Nero will do exactly the same and mess up the mpeg if its not correct.Originally Posted by sandraanddavid27
TMPGEnc > Load > PAL/NTSC Vcd template
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 13:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 14th Apr 2010, 00:25 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 16:55 -
problems burning iso
By hamilton accie in forum Authoring (DVD)Replies: 1Last Post: 26th Sep 2007, 17:41 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 20:53
