Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 100
  1. Member DB83's Avatar
    Jul 2007
    Just one of the forum's rules that you should take note of:
    Please try not to "bump" your topic.
    Replying to your own topic to get it to the top is annoying. Try to have some patience, this is a bulletin board, not IRC. It may take some time (e.g., one or two days) before someone can answer your query or question.
    Make that 8 days now, LS.
    Jan 2012
    North America
    How many forums are you on this week? I know you're chasing LordSmurf around on a few of them.
    What about the disk errors and their relationship to fungus and case corrosion?
  3. Lordsmurf please answaer my questions
    if my DVD disc has errors jitter, PIE, and C1C2 PIPO data burned that disc will be automatically deleted and I will not be able to use the dvd drive in the future?
    I still do not understand what is errors jitter, PIE, PIPO and C1C2 and these errors will corrupt the files burned to disc in the future
  4. Member DB83's Avatar
    Jul 2007
    9 days
  5. Member Cornucopia's Avatar
    ALL.DISCS.HAVE.ERRORS.
    Jitter is just a timebase error, which should NEVER be worried about as long as it is within the bounds of error correction (which it usually is - things have to get VERY BAD for timebase errors to be outside the tolerances of EC).*
    C1, C2, PIE, PIF, POE, POF, etc are all ways of counting the type/placement/difficulty of errors. You don't need to know exactly what they mean, just that they exist, but your disc drive (and software/firmware) already has built into it the means with which to detect & correct the errors. There are multiple stages. Only when an error is so egregious that it cannot be corrected, THEN it is a true data read error. That is the ONLY time where you will lose access to previously recorded data. This does not EVER mean it is deleted. EVER. Only you can do that, on purpose or by accident, and only on RW media. On R media or ROM media, it is ALWAYS still there, it just at some point may not be accessible.
    But, as was mentioned by Lordsmurf, that cliff-point is more like a bluff, because - little known fact: underlying all digital media is the physical layer which really still acts like analog.
    So, back to errors again: underlying soft errors build up to the point where they can't be corrected anymore, and become hard errors. Where is that point? It changes, based on varying factors of disc dye, drive writing & reading strategems, error correction algorithms, disc structure quality, and SCRATCHES. But you don't need to know all those factors and what each one means and it's relationship. To get a full understanding takes degrees in Physics, Optics, Chemical Engineering, Electrical Engineering and/or Computer Science. And nobody here, including LS, wants to tutor you to that point. You want to know? - Go to college.
    Want to instead learn what is important about all this stuff? Then just read between the lines in forums such as these and:
    1. Stop pestering people so much
    2. Listen thoroughly to the good answers given to you
    3. Accept the advice of those already more learned than you
    ...and, related to and underlying all your recent questions...
    4. Only buy very high quality media (TY, MAM, Good Verbatims, etc. as mentioned on these sites) and use multiple, preferred quality drives
    5. Check your discs regularly (~ every 6 months or year). When they start growing more soft errors, or already have much, you
    6. Migrate your data to New, Replacement discs. But also,
    7. Make duplicates of your data on different type media (HDD, Flash vs. Optical, etc), and finally,
    8. Live with the fact that there WILL still be things lost. ALL THINGS MUST PASS...
    Now, if you continue to ask more, repetitive questions after that, you really are acting irresponsibly & troll-like.
    *The only time data jitter ever even comes into play is in A->D (variable depending upon quality), D->A (variable, but usually miniscule), and with hard read errors (mentioned above).
    Oct 2005
    666th portal
    i'm having really good luck with 5 disc raid 10 arrays. haven't ever lost a single bit.
  7. Member DB83's Avatar
    Jul 2007
    @Scott
    A very good write-up. I will not lose much sleep on the OP's failure to understand or believe since it is not written by LS.
    BTW I have this PIE and I lose bits every time I take a byte. Should I be worried ?
  8. 1 from what I understand errors jitter, PIE , PIPO and C1C2 will not delete any files burned on DVD medias?
    2 all these errors are only errors reading the DVD drive correct these errors ?
  9. Member Cornucopia's Avatar
    #1 No. Read what has already been (fully) told to you - AGAIN. I won't tell you after this.
    #2 Reading errors? - Yes. Correctable - Maybe yes, maybe no. See #1.
    I'm done with this thread.
  10. I've read everything but as I did not understand I thought errors jitter, PIE, PIPO C1/C2 would delete my files burned on DVD, but it will not happen? I believe that my discs may have these errors because I just did the test ScanDisc Nero DiscSpeed ​​and no found problem
    Jan 2012
    North America
    If you read everything, then you'd learn. But since you can't understand what is being written, I wonder WHEN you will learn to understand?
    Besides, only disc fungus can eat your data. Especially stored in corrosion-filled cases. Just turn up the speakers - you won't hear a thing.
    Well, at least I see you're coming up with these same questions on other forums, too. Congratulations. You keep getting the same answers and you continue to insist you understand none of this.
  12. Cornucopia or Lordsmurf
  13. Member DB83's Avatar
    Jul 2007
    10 days
  14. Banned
    Feb 2013
    Does he just copy and paste his posts?
  15. Video Restorer lordsmurf's Avatar
    Yes.
    When he bumps them at digitalFAQ.com, they just get deleted.
    If he keeps on, he'll get banned, which is a shame, because I think the questions are good.
    But, seriously ... PATIENCE!
    I wasn't joking. It's up to 10 days now.
  16. man, I do not want to be banned but also do not want to be without a conclusive answer, I just want you to answer me if my burned DVD medias have errors jitter, PIE, PIPO, C1C2 these errors will delete the files that are burned on discs? Just answer me this because you told me these errors and I was worried
  17. Member DB83's Avatar
    Jul 2007
    Carry on bumping and even Baldrick will eventually lose patience.
    11 days.
  18. Banned
    Feb 2013
    gamemaniaco
    I'm not lordsmurf or Cornucopia in terms of Knowledge of this subject, BUT I'M TELLING YOU RIGHT NOW THAT ALL BURNED DISCS HAVE ERRORS. THE LONGEVITY OF YOUR DISCS DEPEND ON THE QUALITY OF THE MEDIA AND THE QUALITY OF YOUR BURN. ALL BURNED DISCS EVENTUALLY STOP BEING ABLE TO BE READ!!!
    To all others I apologize for the yelling.
    lordsmurf
    I like digitalFAQ.com, lurk there every so often. I notice his posts there too.
    His questions might be originally good, but he makes no effort to try and understand the answer. This applies to Brazilian sites as well, which would be in his native tongue.
  19. I do not care about quality of medias I just want to know if errors jitter, PIE, PIPO and C1C2 will delete the files burned on my DVD medias, my burned DVDs can have these errors but
  20. Member DB83's Avatar
    Jul 2007
    Oh fook. I just run out of fingers.
    Aug 2006
    Take of your shoes and socks. That is what I always do when I run out of fingers. Twelve days!
  22. Banned
    Feb 2013
    The problem is when you hit 20 days.
  23. Banned
    Feb 2013
    If you don't care about the quality of the media then you don't care about the errors.
    Nothing left to discuss!!!
  24. dude I know that the quality of the media interfere in the durability of the files but do not confuse things I just want to know if errors jitter, PIE, PIPO and C1C2 if these errors will delete the files burned on DVD media?
  25. Banned
    Feb 2013
    Does his English get really good every so often?
  26. Member
    Aug 2006
    Yes.
  27. Member
    Aug 2006
    Then I just ask a friend for help.
  28. guy I just want to know if errors jitter, PIE, PIPO and C1C2 if these errors will delete the files burned on DVD media?
  29. Banned
    Feb 2013
    Thats one way to count to 21
  30. respond my answer
