Hey Guys,
I'm new to the field but I was sort of baptized by fire at work and now I need to be able to convert video files NTSC <--> PAL.
I am in the TV business so we deal with all sorts of codecs and we need minimal quality loss to keep the broadcasters off our ass.
I read that Nattress' plug in for Final Cut Pro 7 was the best available, but the people we used to outsource to vouched for Final Cut X with Compressor.
Which do you think is better and why? We will have a new dedicated iMac computer to run these conversions, so quality and speed are the two most important features.
Having experienced Compressor, and looking at the demo for Nattress, I would say I'm underwhelmed by both, afa standards conversion. Give me AVISynth over those any day (both quality and speed).
Scott -
Really? It seems to be script based.
Is there a steep learning curve on this one? Or perhaps a wiki or pdf guide?
The short end of it is that I will need to take files (generally .mov Apple ProRes files) of HD & SD episodes, and run them through the program for a basic standards conversion. This does that? -
So one topic is not enough for you ?
And since you are using a mac you really should be asking these questions on the dedicated mac forum. -
I think after saying, "broadcast," "the best," and "money is no object." in his last thread -- and getting a good answer that met those criteria, he's had it walk it back.
Seany, Avisynth isn't too hard to learn, but you're going to need parallels to run it on a mac. -
Compressor is fine for progressive sources, but crap for interlaced.
Indeed, Avisynth is better.Want my help? Ask here! (not via PM!)
What is the best compressor to use???
By BobAchgill in forum EditingReplies: 7Last Post: 13th Sep 2011, 06:55 -
1080p Standards?
By thezanny in forum Video ConversionReplies: 4Last Post: 17th Aug 2011, 10:37 -
HDV7 compressor is ..... ?
By ermetekos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 3rd Nov 2009, 14:00 -
VidFIRE processing & Reverse Standards Conversion
By lordsmurf in forum Video ConversionReplies: 3Last Post: 10th Apr 2009, 06:56 -
New Youtube standards
By johnnywellas in forum Video Streaming DownloadingReplies: 26Last Post: 11th Dec 2008, 20:17
