Hello everyone!
I have some AVI files that are the result of a GeoVision camera recording. I tried to run it on Linux using different software, but without any success. Trying to convert this file with ffmpeg:
Code:./bin/ffmpeg -i /path/to/my/file.avi -c:v libxvid output.avi
I got this output:
When I try to run this video with VLC, it gives me this error:Code:ffmpeg version git-2013-10-10-65c2fe7 Copyright (c) 2000-2013 the FFmpeg developers built on Oct 10 2013 09:14:31 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1) ... [avi @ 0xa670d40] probed stream 1 failed [avi @ 0xa670d40] Could not find codec parameters for stream 0 (Video: none (GAVC / 0x43564147), 1920x1080): unknown codec
"No suitable decoder module:
VLC does not support the audio or video format "GAVC". Unfortunately there is no way for you to fix this."
On FFMpeg forum, they told me that this video format is not supported yet by them.
Can anyone help me to solve my issue? I would need to convert this kind of video in many formats (ogg, webm, mp4).
Thanks in advance.
P.S. I hope to post the question in the right forum.
I have only seen a GAVC decoder/codec for windows, see https://forum.videohelp.com/threads/344612-Cannot-play-avi-file-with-vlc-player-divx-pl...highlight=gavc
I doubt ffmpeg or vlc will add gavc support any time soon. -
Yes, it's a proprietary codec from Geovision. That's common with cctv etc. companies.
Which is why vlc & ffmpeg (or other open source) programs don't support it and aren't likely to soon. It's not an open source codec.
I had a quick look and the only source I see is a download from geovision itself, which is much better than you'd usually get for such things, but it's only for windows.
There are non-free codecs available for linux, but it'd be a Hail Mary. You didn't say what distro you're running but in ubuntu the package is called ubuntu-restricted-extras (or in my case kubuntu-restricted-extras since I prefer the kde desktop). I don't think it'd work but it should be one of the first things you install.
In your case, if you don't have a windows partition, I'd explore running a windows program under wine. -
In all likelihood there's nothing proprietary about the codec other than the fourcc they use. I'd try changing the fourcc to H264, AVC1 or XVID.
I would like a list of dos equivalent commands for linux (linux noob)
By yoda313 in forum ComputerReplies: 6Last Post: 6th Jan 2013, 10:00 -
Linux: How to Convert .SMI file to .SRT
By chiappa in forum SubtitleReplies: 4Last Post: 30th Jan 2011, 04:10 -
Linux as a file server
By Nelson37 in forum LinuxReplies: 8Last Post: 28th May 2009, 21:25 -
(linux) Problem downloading flv file [solved]
By aboa in forum LinuxReplies: 2Last Post: 25th Mar 2009, 12:56 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27
