I have a large Mp4 file that has very, very low volume whenever played. I have spent about 2 hours searching for a good tool to increase the gain with no results. the only one i found and tried was Avidemux 2.6, and it didn't work as expected. anyone know something i can use without re-encoding the whole file?
You can do it by seperatly encoding audio while not touching the video.
1) Download beta_2307 from https://bitbucket.org/ozok/taudioconverter-audio-converter/downloads (only in beta version this func works)
2) Add your video file to the list.
3) Set codec, bitrate etc.
3.1) Make sure "Method" is "Encode Audio"
4) Click to "Filters" button. Check "Change volume" and set value in percentage. Start encoding.
5) If it all goes well, you'll have an m4a file in output folder. You can then mux this audio stream with video using a mp4box GUI or mp4box itself. -
May I suggest trying VideoGain course there are a few other app's on the forums that do much the same thing.
However it will re-encode your audio stream...but not your video stream....well unless you select re-encode for H264...and your video stream isn't H264. If it's already H264 even if re-encode is selected it won't encode the video stream. -
One possible problem. If the audio is at a very low level and if you just boost it, you may also boost all the noise.
If you do make major changes, do it on a copy of the original or just use a small sample of the original for experimenting with, so you don't damage the original.
If you need a more 'in depth' audio editor, try the freeware Audacity or something similar.
But you will have to learn how to demux the audio from the video, process it and then mux it back in.
And welcome to our forums.
The easiest way to do this is to use TMPGEnc Smart Renderer 4.
Fixing audio is 99% of the reason I bought it. That and sync fixes.
It's so simple with this tool.Want my help? Ask here! (not via PM!)
MP4 (h264+AC3) How to modify the volume without reencoding the h264 ?
By nimook in forum Newbie / General discussionsReplies: 6Last Post: 11th Oct 2013, 07:46 -
raise volume for sections of mp3?
By charlieship in forum AudioReplies: 19Last Post: 29th Sep 2011, 17:29 -
How to fix uneven audio volume in MKV/MP4/AVI files?
By ConverterCrazy in forum RestorationReplies: 5Last Post: 19th Jul 2010, 00:26 -
What Program is best suited to raise volume of ripped DVDs/AVI?
By V Bot in forum AudioReplies: 2Last Post: 13th Jun 2010, 16:13 -
Sony Vegas 9.0 Platinum how do I raise and lower the volume?
By LoveMyslf in forum EditingReplies: 1Last Post: 7th Nov 2008, 13:28
