I have previously owned a video camera which was not compatible with PC. I used a very sophisticated video controller which also added music. I now have a Panasonic camera HDCTM300 with HD writer AE 1.0 software,cannot add music and then burn to C.D with this software. I can add it afterwards using my video controller but then I have defeated the object of using the software, Is there any possibility that I can download a later version which will work with this camera and add music. I have also nero on my P.C. CAN I USE THIS.
It's there in the manual about page 70, looks pretty limited. What do you mean exactly by "sophisticated video controller?"
http://www.panasonic.ru/upload/iblock/8d8/hd%20writer%20ae%201.0_eng.pdf -
I use a panny which produces AVCHD video and use Powerdirector to add all sound effects (church bells, traffic, bird songs and so on) plus a couple of extra tracks for music.
Its quite easy to just drag and drop the sound files (vob, wav, mp3 etc) into the software and it has some pretty simple audi editing tool as well.
once done - you click the "produce DVD" and hey presto.
Enquiries@celestialvision.co.uk -
Thank you this looks interesting I will have a look at this I had an older version which I cannot use on windows7 but it was not that sophisticated
The new version of Powerdirector (I use the 64 bit version) is actually very good. Sometimes "less is more" and the more toys you have to play with the less work you get done.
Have fun
enquiries@celestialvision.co.uk -
In answer to your other query I have a keene video controller the camera and a stereo are connected the outlet to a DVD recorder. levers are used to control the sound video and music track. But because it uses scart sockets it is analogue so defeats the object of having H.D. Also scenes cannot be moved and titles cannot be added
Adding Music To Video File
By tater259 in forum EditingReplies: 4Last Post: 2nd Apr 2013, 18:27 -
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 03:02 -
Adding music to video question PowerDirector
By 10pmStalker in forum EditingReplies: 8Last Post: 4th May 2011, 07:03 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07
