@sanlyn: dead link
Results 31 to 54 of 54
Fixed it. I used the jpg instead of the png, which screwed up the npage layout.
OOOOps. OK now.Last edited by sanlyn; 21st Mar 2014 at 09:25.
Adding Tweak(Hue=15, sat=1.5) to my earlier script will get colors and saturation similar to that but keep the white balance adjustments. But I think it looks way over saturated in other shots. ColorYUV(cont_v=100) will also give about that same adjustment. But overall I think ColorYUV(cont_u=-50, cont_v=50) looks better, less over saturated in places.
For those who don't know: cont_u and cont_v in ColorYUV increase the color saturation when positive values are used, decrease the saturation when negative values are used.Last edited by jagabo; 11th Oct 2013 at 16:33.
The TTempSmooth is just too aggressive. The original film has some grain, so it's not just digital noise. You can tolerate some. I think frameserving this into VDub and using some of those NR filters will be better here. Aviysynth is nice, but has it's weaknesses. Maybe a combo of the two.
You need this early in the script:
And I think some of the script ordering needs to be changed.Code:ChromaShift(C=0, L=-2)
santiag() and AAA() isn't working as well as I'd want, but both are giving better results than santiag alone.
I'm not sure if LSFMod is helping much. In fact, I think it's making things worse, for the edge noise and aliasing.
I've never used HqDering(). Are you using a stock version, or a modded one with MaskTools? I can't find that one either. (I could guess, but would rather have yours.)
Add deen() for edge noise.
I'm still messing with it.
There's different errors per episode. This is an easy one. Several eps in, it has blurring and duplication of fields. SRestore() will be my attack there.Last edited by lordsmurf; 11th Oct 2013 at 21:17.
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
I found HqDeringMod on another site. But I don't see that it doing anything, aside from adding more filter time. What is the purpose of this filter?
I've fixed most everything for this one, and the video is encoding now. The first ep was one of the best, quality-wise. Less issues on this one.
Need to do the audio. Again, one of the better eps here.
The sample I want some input on is the one with blurring -- episode #2.Want my help? Ask here! (not via PM!)
I don't think HqDering did much here either. I was hoping it would remove some of the DCT ringing. If you find Deen works better go ahead and use that.
For the OP: I never had much luck with the AviSynth deflicker filter. You can use Donald Graft's deflicker filter for VirtualDub in AviSynth scripts with:
Change the path to the plugin to reflect where it is on your computer. If you crank this up enough to stabilize the background (the softening setting) you will run into the same type of problems you get with TTempSmooth.Code:LoadVirtualDubPlugin("g:\Program files\VirtualDub\plugins\deflick.vdf","DeFlick") ConvertToRGB32() # VirtualDub filters need RGB32 #DeFlick(window size, softening, interlaced, scene change threshold, show scene change) DeFlick(8, 6, 0, 10, 0) ConvertToYV12() # assuming want it back to YV12Last edited by jagabo; 12th Oct 2013 at 09:34.
The video on the first one turned out really good. I've fixed all the colors, removed most noise without side effects, etc. But that was the easy one! I'll post samples later. (I shouldn't be doing video on this system. It's not optimized for that.)
What I may do is use this thread to chronicle what I'm doing, per episode, so others can learn. Brief notes here, and detailed ones at the digitalFAQ.com forums. I've not had fun in almost a year now, and this is my idea of fun!
And indeed, it's so I can learn from others if needed! I'm always eager to trade tips! (I'm not one of those a-hole pros that never shares. If you've read my bio, you know I was there myself 15+ years ago, and it sucked. There was no magic internet where you could learn these things yet!)
So stick around jagabo, sanlyn, cornucopia, manono and others! I'm going to subscribe to the thread -- something I rarely do here.
26 eps makes for a nice case study.
I can't wait to see this. I've been interested in the video and audio restoration process for a few years now, and would love to be able to learn more about it. And thanks for helping me out with all this lordsmurf.
Playing with Episode 2 (Ostrich). More work than play. Biggest problem(s): (a) I gave up trying to deblend the damn thing. (b) the "flicker" isn't flicker. It's block noise and banding that moves and varies. Literally, large patches of color are missing. No bitrate to work with. Seems to have started as 29.97 telecined, then blend deinterlaced and whatnot to get to 25 FPS (that's a guess, but definitely had 3:2 pulldown at one time). Genius who sought to ruin this video succeeded admirably.
Have to take time off and find some food for the family.Last edited by sanlyn; 21st Mar 2014 at 09:25.
I can post a new version of Ostrich if needed in better bitrate, quality, and color.
That would be preferable, thank you.
1. Always provide the best quality that you can acquire! Do not be lazy, as I despise "good enough" (lazy attitude). I don't need to waste time restoring crap if something else better is available to work from.
2. Always provide alternative sources when available. Even if you think they're worse, they may be easier to restore. Let me decide what's best, and what's not. The obvious exception is if it's truly butchered -- tracking errors encoded into the video, small fuzzy resolutions, etc.
3. And then don't overwrite earlier files -- change the name to "v2" or whatever.
____
I'll be upfront with you, NOT doing that is going to piss me off.
It makes things needlessly complex, and may require extra work that wasn't necessary.
Just communicate what's what at all time. No silent changes, no holding back if you have alternatives.
So, before I start, are there any more that have better/alternative sources?Last edited by lordsmurf; 12th Oct 2013 at 23:21.
There's one for episode 17 (Theodore's Dog) It's up now. Episodes 2 and 3 had the same source but were "restored" horribly by friends of mine.
Yeah, the new 2-3 eps are better to work with. Whoever "restored" those just butchered it.
I'm not sure about ep17 -- v1 has good things, v2 has good things. I may try to fix v1 first. The blending and lower res is what makes v2 less desirable. The chroma and audio noise is easily corrected. (Well, easy if you know what you're doing.)
Yeah, it's not easy, but challenging and fun. I always like to think of how I'll have this awesome DVD on a shelf, complete with artwork, pop in my discs with excellent menus, and enjoy my work. I've done this for myself for 20 years now. Rarely does somebody present me something that I'd also like to see, something not easily found.
Have you checked Youtube, DailyMotion, Google search site, and trading forums/groups, to verify that this is indeed the best source around?
Example: This one is better! http://www.dailymotion.com/video/xzap7s_the-alvin-show-alvin-s-alter-ego_shortfilmsWant my help? Ask here! (not via PM!)
That's actually a old Dailymotion upload of mine :P Must've forgotten about it.
Back in September of 2009, one Alvin Show episode was released on DVD. BUT it was from the syndicated run, not the original CBS versions. Nothing new has been released since.
Also, here's a better version of Sam Valiant: Private Nose (Episode 4) It will be on Dropbox soon. I forgot this was one of the episodes I got in trade. http://www.dailymotion.com/video/x15o9ot_the-alvin-show-sam-valiant-private-nose-syndicated_creation
EDIT: I see what's what now, for the release.
Do you have the DVD release? The download is crap compared to a release.
The most original version of something is always best. Not a later reencode. Sites like Youtube/etc are a last resort. Ideally, you want tapes, MPEG-2 (home conversions), etc -- not download or streaming site versions.Last edited by lordsmurf; 13th Oct 2013 at 16:07.
I have many contacts. Before starting, I'm want to see what else I can get.
Downloads for old shows like this had to start somewhere else -- usually VHS. Those, in turn, may have been converted to DVD using shoddy methods. But still, it's often better than yet another re-encode that you found online. The goal is to locate the tapes and DVDs.
So this is on hold for now.Want my help? Ask here! (not via PM!)
I got about 10 VHS rips from someone in trade. If you want, I can direct you to that person.
EDIT: Here's the person: http://forums.stevehoffman.tv/members/antifrodis.11891/ -
Well, VHS capturing Mostly cartoons, having some questions:)
By zerowalker in forum Capturing and VCRReplies: 943Last Post: 30th May 2013, 23:30 -
Getting Serious about restoring
By DeeSeven in forum RestorationReplies: 6Last Post: 18th Oct 2012, 09:40 -
H264/AVC B-frames in cartoons
By DrDeceit in forum Video ConversionReplies: 11Last Post: 1st Oct 2012, 21:27 -
Restoring mini DV
By Hesam in forum RestorationReplies: 2Last Post: 1st Sep 2011, 19:54 -
Ripping Single Episodes of Cartoons for Re-Authoring - Jaggies
By jdmba in forum DVD RippingReplies: 7Last Post: 5th Aug 2009, 13:19
