Hey..
first of all i wanna thank all people that helps out in these forums, i've learnd alot just from reading these post..
Now here's my problem.. I just bought a WinTV-FM tvcard and installed it, first using the drivers from the cdrom, and from their webiste.
The installtion seemed fine.. but when i try to capture using any prog i can't choose the wintv drivers, just microsfts WDM drivers..
i've tested this in Vdub, avi_io & AMcap.. i get same error.
In virtualdub after choosing Capture Avi, i have these two options under the "Video" menu..
0 Microsoft VDM Image Capture (Win32)
1 Hauppauge Win/TV Video Capture Driver
vdub selected microsoft's drivers as defualt.. but when i choose the second option i get these error messages:
Error 418: Capture Driver is not installed properly. (after i hit "OK")..
VirtualDub cannot connect to the desired capture driver. Trying all available drivers.
And im using the latest XP drivers from hauppauge's website.. when i capture using microsoft's drivers i can't choose any resulution higher than 325x...
Now I don't know what to do, If you have any tip at all i would really appraciate it.. Thanks.. (Btw. I'm Using Win XP, GF2, Intel motherboard 810 chipset)
/Funk Master Flex![]()
NM replying i got it work :D..
just installed win2000/NT drivers (VFW)
w2kdrv311.exe (http://www.hauppauge.com/html/sw_nt.htm)
..and everything works fine now, if you got the same prob.. i recommend you to do the same.
help with my converting people
By charlie_b in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 30th Apr 2009, 10:47 -
Trails off of people?
By thewahls7 in forum Capturing and VCRReplies: 13Last Post: 23rd Sep 2008, 15:10 -
why do people still use macs?
By aedipuss in forum MacReplies: 190Last Post: 27th Apr 2008, 07:12 -
Either people are lying or something is up!
By 1magus in forum DVD RippingReplies: 3Last Post: 25th Jul 2007, 03:40 -
which one of these people is yoda313??
By Xylob the Destroyer in forum Off topicReplies: 1Last Post: 31st May 2007, 12:17
