Hi All,
I am wondering if it is possible to set-up Daum PotPlayer to skip the intro and credits when
the show / file doesn't have separate chapters. I often watch multiple episodes of the same series and it can get annoying having to watch the introduction and credits over and over especially when the shows are 20- 25 minutes each. I know that in VLC Player their is a plug-in called "Intro and Credits Skipper" that let's you define the amount of time to cut off of the beginning and the end of each file in a playlist. Is there anything like this in PotPlayer?
thanks!
How long did you spend looking for it? I'll bet a lot less than three weeks. I'm a Pot Player newbie, and never have used the skip feature, but it only took 5 minutes for me to find it.
1. Playback->Skip->Skip Setup->Enable Skip feature
2. Enter seconds for intro and endingLast edited by usually_quiet; 28th Oct 2013 at 19:53. Reason: changed time to seconds
Potplayer. Make both upper and lower part of skin show up simultaneously?
By hemstock in forum Software PlayingReplies: 0Last Post: 15th Sep 2013, 10:35 -
MPC-HC & Potplayer.How can I avoid aliasing of progressive fullHD videos?
By Stears555 in forum Software PlayingReplies: 18Last Post: 14th Jan 2013, 09:36 -
Can't find DVD/BD menu's on Daum Potplayer, any help?
By joruyyy in forum Software PlayingReplies: 6Last Post: 3rd Dec 2012, 02:38 -
show 2 subtitles at once one on the top and one on the bottom in potplayer
By innn in forum SubtitleReplies: 0Last Post: 1st Jul 2012, 10:36 -
Media Player Classic Home Cinema - how to not skip intro?
By danelsan in forum Software PlayingReplies: 1Last Post: 30th Dec 2011, 09:15
