  1. Originally I had an ADVC300 and an 8710 TBC. (both now gone)
    I have a Panasonic S-VHS player ... and I want to carry out capture of a bunch of PAL VHS tapes a mix of VHS and S-VHS
    Presuming as before I run Firewire direct into PC and use WINDV .... what hardware would be the best to get.
    This is only a 'family' project on converting tapes .......... would appreciate advice on what to buy.
    Post capture I will use Vegas Movie Studio to edit and then create DVD.
  2. Member DB83's Avatar
    Jul 2007
    From the other topic, DV is a compromise. To achieve that now you either get a capture device that outputs DV (???) or loop the video through a DV camera.
    A better option is a dedicated capture device which allows you to capture lossless.
  3. Member Cornucopia's Avatar
    In an effort for efficiency, I'll only reply on the other thread...
