I have a movie that I want to encode to PAL. Even though the standard resolution is 352x288, I want to keep it 352x240 so it won't be stretched. Does anybody know if this will work, like on a DVD player?
Most tv's sold in pal regions are in fact multiscan tv's, meaning they can support both pal and ntsc signals. Furthermore, almost all dvd players that support pal will also support conversion from ntsc, since it doesnt actually have to convert the signal just modify it, unlike when you go from pal to ntsc.
So in all likelyhood, your setup should be able to properly play an ntsc
(s)vcd. I would keep it as it is and see if it works. You should not mix and match regional formats ie: 352x240 @25fps, I think that would definitely cause problems on many dvd players.
PAL - what is its resolution in 16:9 broadcasts?
By snadge in forum DVB / IPTVReplies: 19Last Post: 22nd Oct 2013, 06:01 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 20:45 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 17:30 -
PAL is bigger resolution than NTSC....?
By snadge in forum Newbie / General discussionsReplies: 17Last Post: 19th Jan 2008, 12:18
