Hey everyone,
I would like to know more information on h.264 profiles and converting.
h.264 profile: High 10 @L5.1
I would like to understand what each part means.
Also when i convert this file from 10bit to 8bit, the file goes from 1.8GB to 900MB. I thought when you converted 10bit to 8bit the size of the file was meant to increase.
I check the information (before and after shown belowWhen converting have i lost quality (if so how much/ will it make a difference).
Only difference i can see is the "codecPrivate, length 45 (h.264 profile: high 10 @L5.1)" - "codecPrivate, length 42 (h.264 profile: high @L4.0)"10bit file
A track
track number: 1 (track ID for mkvmerge & mkvextract : 0)
track UID: 1
Track type: video
Lacing flac: 0
mincache: 1
codec iD: V_MPEG4/ISO/AVC
default duration: 41.705ms (23.976 frames/fields per second for a video track)
video track
pixel width: 1920
pixel height: 1080
display width: 1920
display height:1080
A track
track number: 2 (track ID for mkvmerge & mkvextract : 1)
track UID: 171
Track type: audio
codec iD: A_FLAC
codecPrivate, length 113
default duration: 85.333ms (11.719 frames/fields per second for a video track)
name: 5.1 FLAC 24bit
audio track
sampling frequency: 48000
channels: 6
bit depth: 24
8bit file
A track
track number: 3 (track ID for mkvmerge & mkvextract : 2)
track UID: 1
Track type: video
Lacing flac: 0
mincache: 1
video track
pixel width: 1920
pixel height: 1080
display width: 1920
display height:1080
A track
track UID: 171
Track type: audio
codec iD: A_FLAC
audio track
channels: 6
bit depth: 24
https://en.wikipedia.org/wiki/H.264#Profiles
https://en.wikipedia.org/wiki/H.264#Levels
file size = bitrate * running time (plus a little overhead for the container) -
"plus a little overhead for the container"
depending on the container the overhead might be more than two times the size of the raw files.
The OP is working with 1080p video. There is no container that will give 2x overhead for any reasonable bitrate for that. We're talking about 1 percent for most containers.
okay, not wanting to go into the discussion what might be a reasonable bit rate.
New ripbot264 profiles
By jamesj84 in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2012, 09:09 -
RipBot264 Profiles?
By shagratt71 in forum Video ConversionReplies: 2Last Post: 13th Dec 2011, 06:00 -
XMediaRecode... Levels and Profiles?
By smackyourfupa in forum Video ConversionReplies: 3Last Post: 14th May 2011, 14:52 -
libavcodec x264 profiles
By Spearmint in forum ProgrammingReplies: 0Last Post: 2nd May 2011, 20:57 -
Player's color profiles?
By juhah in forum Software PlayingReplies: 13Last Post: 20th Feb 2010, 14:22
