I'm going nuts with this, because when I google for this issue I only come up with posts from 2009, 2010, 2011. This is so old and I'm having to deal with this now.
My current computer (which is a little bit old, I can agree to that) is a Core2Duo 1.5Ghz with 2GB of RAM. But up until yesterday I was using a WORST one (DualCore 2.4Ghz) and it was playing everything smoothly without a glitch. Now 1080 files simply won't play. They'll skip, go mute, drop frames or stop playing altogether. CPU usage is not that high (max 60%).
My Windows is 7 Ultimate 64bits (with Sp1).
I have tried: MPC-HC 64bits, VLC, CCCP pack, K-Lite pack (32 and 64) and even CoreAVC, with many different types of configurations: with Haali and LAV as splitter and with LAV and ffdshow for video codec. The 720 files all play perfectly, but it doesn't seem to be a matter of resources because the computer doesn't "hang" or get all slow when I'm playing the 1080's, and the CPU never reaches 90%.
Could it be something related to my graphic card? It's a Intel 965 family.
Please help, because I'm very close to formating the computer and install everything from scratch.
1.5 GHz C2D (mobile? even worse) is probably too slow to play 1080p24. Definitely too slow for 1080p60. It doesn't matter that your CPU isn't exceeding 90 percent. When the CPU senses it's falling behind it will try to seek forward to catch up. That seek takes time, during which the CPU goes idle. You only see the average CPU usage in Task Manager.
I had an Intel G965 with a Pentium D 945 that was supposed to support 1080p but had trouble with most. I had to buy a decent graphics card.
Typical min cpu requirement for 1080P content is a 2.0ghz dual core.
Having said that, the file type, the file specs, the media player, and the codecs used by the media player can all have an affect as well. So when the hardware is borderline, any little thing can make a file not play properly.
In general, as you state "720P" files play fine and "1080P" files do not, the hardware is not capable.Google is your Friend
playing MP4/MKV/H.264 files with USB thumb drive
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2012, 21:42 -
Convert MKV files to AVI OR MP4 for Playing on Sony EX520 TV via UBS port
By premsoni4u in forum Video ConversionReplies: 2Last Post: 16th Jul 2011, 04:45 -
Problems playing MKV 720 & 1080 - Not enough PC ?
By NotSoEasy in forum Software PlayingReplies: 8Last Post: 7th May 2010, 12:30 -
Why video and audio out of sync while playing .mp4 and .mkv files?
By Bonie81 in forum Software PlayingReplies: 0Last Post: 6th Apr 2010, 18:03 -
WD TV, Audio problems on 1080 mkv files.
By gustav32 in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th May 2009, 13:28
