Hi - I am new to the world of recording live streams and would appreciate some help in attempting to record live streams from www.rte.ie/live
I've analyzed the HTTP traffic and it seems that the client browser invokes 4 .f4m files as follows:
http://livehds.rasset.ie/hds-live/_definst_/rte2/rte2_288p.f4m
http://livehds.rasset.ie/hds-live/_definst_/rte2/rte2_360p.f4m
http://livehds.rasset.ie/hds-live/_definst_/rte2/rte2_540p.f4m
http://livehds.rasset.ie/hds-live/_definst_/rte2/rte2_720p.f4m
I can use AdobeHDS to create an .flv file against one of these manifests. However, when I do so, the script terminates after a few minutes.
The reason, as far as I can tell, is because when the browser is streaming it seems to alternate between the above 4 manifests. Whereas AdobeHDS is only downloading from one.
Even if I move away from AdobeHDS and try to use the temp files downloaded from Chrome, I still cannot manage to play these files. The trid application identifies the temporary files as .swf but when I attempt to play them then using Adobe Flash Player it fails.
Has anyone attempted to record from similar sites before, and if so, how?
Thanks!![]()
php AdobeHDS.php --manifest "http://livehds.rasset.ie/ hds-live/_definst_/rte2/rte2_720p.f4m"
Thanks, I actually used this manifest instead and all works great: http://www.rte.ie/manifests/rte2.f4m
RTE RTMPE Ripping (How to rip of RTE player)
By rteripper in forum Video Streaming DownloadingReplies: 584Last Post: 29th Mar 2025, 04:22 -
Split recording a continuos live stream
By GordonFreeman in forum Video Streaming DownloadingReplies: 3Last Post: 29th May 2010, 19:09 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 06:14 -
live stream bitrate
By onyx808 in forum Video Streaming DownloadingReplies: 3Last Post: 28th Jul 2009, 03:46 -
Live stream recording: how to make it continuous
By igorek in forum Video Streaming DownloadingReplies: 1Last Post: 25th Oct 2008, 19:29
