I converted a vhs to dvd using Dazzle by Pinnacle. The converted image looks like you are looking thru a black window with a black border and section in the middle. not sure what to do. I converted several before but didn't realize I didn't have the audio plugged in. All those dvds looked good, just no sound. I believe this is an older product and have tried to get help online without any luck. Any ideas?
It sounds like you converted a 4:3 letterboxed VHS into a 16:9 DVD, thus adding black borders to the sides as well as top and bottom. Try redoing it as a 4:3 to 4:3 conversion.
I'm not sure if this is actually a question. You have to redo them properly with sound. Or are you saying there was no windowboxing on these? If so, what did you do differently?
BTW, "split screen" has a specific meaning, so please don't use it in this situation. -
thanks for the help..i will give it a try, i understand the term split screen, i guess it's more like looking out a black window pane will the 4:3 take care of that? I mentioned my other attempts to convert by way of saying i didn't have a problem with the "window pane effect" just the audio, which was fixed by plugging in the audio plug!
Sony Vegas split-screen settings
By ArneWarm in forum EditingReplies: 1Last Post: 12th Nov 2012, 18:15 -
3D movie is split screen
By littlealbert in forum Newbie / General discussionsReplies: 4Last Post: 12th Oct 2012, 12:42 -
Recording Split Screen Interviews
By ManOfBliss in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2012, 18:49 -
why does 3D movie shows up in split screen on my 3D TV
By greenmetal in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2011, 04:08 -
Split screen in Word 2007
By plainplow in forum Newbie / General discussionsReplies: 4Last Post: 30th Aug 2011, 17:17
