Can someone explain me how to add a watermark to a mkv video file without re-encode?
Thank you!
You can't.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Yes, but the question is: do you re-encode your DVD to h264 or you only mux it to mkv?
If you use the first option you can watermark the video using i.e. hard coded subtitles. I don't remember if Handbrake has option to add a picture as watermark to output video.
If you only mux (change the container from vob to mkv, without re-encoding), then you also can add subtitles. However, in that case they can be removed or replaced by remuxing the mkv file.
How to add a watermark in a .mkv file with Avisynth?
By imam2007 in forum Video ConversionReplies: 1Last Post: 20th Nov 2011, 16:04 -
adding watermark to .mkv with megui without reencode
By sepano in forum Newbie / General discussionsReplies: 4Last Post: 10th Sep 2011, 04:38 -
How to stick subtitle and Watermark to mkv videos without re-Encode
By skydl2011 in forum SubtitleReplies: 9Last Post: 6th Sep 2011, 02:10 -
MKV TO MKV with watermark or text...
By jaseemkannur in forum Video ConversionReplies: 1Last Post: 18th Dec 2010, 03:22 -
How to add watermark in mkv videos
By mysteryman26 in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2010, 01:29
