I just bought the Hauppauge 1512 HD-PVR 2, great unit. But I notice that I get WARNING whenever I try to record a Movie from Directv that I saved on my Directv DVR. Would be awesome to capture these movies via the PVR unit's HDMI cable.
The warning tells me to remove the HDMI cable. So I then connect the HD component cables and I able to record.
My question is Other than setting the Hauppage PVR to it's highest setting which is 14 mbps, and Variable Bit Rate.
That will produce the maximum quality and a huge file at 60fps.
So is that overkill for the Directv's HD 1080P movies? Not all are 1080P, I imagine most are 1080i, which would be the max capture setting for the Component cables? Or am I wrong?
Anyway looking for advice on this. Some older Directv Movies are probably only 720P, I believe.
I appreciate all input and thank you in advance!![]()
dont' set to vbr.., set it to cbr, since you want the highest quality capable with the hdpvr.
i guess i don't have your problem since my directv is SD. i would have to trash my old (RCA) round dish for their newer oval-shaped one that is for hd. at least that is what they told me in order to receive hd content and would need a new (HD) receiver/dvr unit. -
I believe that component video is limited (by design) to 1080i due to is limited analog bandwidth. 1080p is usually only available on HDMI. I don't know about the 1512, but the 1212 set to CBR at 5Mbps gives me (to my eyes anyway) a decent recording (and I've recorded many), and usually yields about a 5GB size file on a 2 hour movie. I've only recorded one movie (documentary) that had some issues with complex scenes of rippling surface water filmed underwater reflecting off the bottom. The bitrate and H.264 compression struggled to keep up with the complex images, but the rest of the film recorded nicely.
You didn't say if you actually recorded anything off your DirectTV box's component outputs. I've read that they dumb down the component outputs to 480p (regardless of the source material), so you may want to double check that. -
To avoid the warning message when capturing from HDMI, you need to connect an HDMI splitter that removes HDCP as a side effect between the satellite receiver and the capture device. See the "HDCP strippers" thread for suggestions.
The HD-PVR 2 can't capture 1080p at 60fps. It captures 1080p60 as 1080p30 using frame decimation, which will be less smooth. 1080i and 720p can be captured at their normal frame rates.
You need to use CBR to capture at a predictable target bit rate. You can try 14 mbps upper limit with VBR, but you probably won't get the average bit rate that you expect.
Hauppauge HD PVR 2 1512 5.1 audio with gaming headset?
By OnlySublime in forum Capturing and VCRReplies: 3Last Post: 18th Aug 2013, 16:05 -
Hauppauge HD PVR 1212 best settings?
By nucklhead24 in forum Capturing and VCRReplies: 4Last Post: 18th Jun 2013, 23:13 -
Hauppauge HD PVR 2 Capture Failed Need help
By Tha Real Jokerr in forum Capturing and VCRReplies: 9Last Post: 19th Apr 2013, 10:28 -
Hauppauge HD PVR (Capture PC gameplay)
By TommyGun in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2010, 09:50 -
Capturing standard broadcasts on Hauppauge HD PVR 1212 - which settings?
By Emanef in forum Capturing and VCRReplies: 2Last Post: 20th Sep 2009, 08:59
