Hi Chaps,
I was wondering if anybody has created a better PAL DVD Template than the one that comes with TMEPEnc? When I encode the colours get washed out and the audio distorts somewhat. Yet when I try the same capture with the VCD or SVCD template, the colours and audio are OK.
I know that some of the more advanced users out there will probably know what to tweak, so has anybody done so? (I haven''t got a clue about all the settings apart from Bitrate, Resolution and the other obvious ones).
Thanks very much if you can help.
Results 1 to 1 of 1
First time opening my DVD pixma i4500 - is there a dvd template for printin
By netrate in forum MediaReplies: 5Last Post: 14th Nov 2011, 09:06 -
How to Create DVD Menu Template from existing DVD
By btodorov in forum Authoring (DVD)Replies: 3Last Post: 28th Jan 2009, 15:24 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 14:25 -
PowerProducer - edit dvd menu template
By kj1983 in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2008, 19:37 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
