I am having a strange issue converting with Handbrake. I have Handbrake 0.9.8 and I am running on a Windows 7 x32 Intel i processor 3 GB RAM computer. I am attempting to convert an MKV file into MP4 for Xbox 360 playback. However, when I hardcode the subs in, Handbrake chokes halfway through the conversion and outputs a corrupt file. Here are the specs of the video:
MKV file:
Stream 0
-Type: Video
-Codec: H.264 (x264)
-Language: Japanese
-Resolution: 1280x720
-Frame Rate: 23.976215
-Decoded format: Planar 4:2:0 YUV 10-bit LE
Stream 1
-Type: Audio
-Codec: MPEG AAC Audio (mp4a)
-Language: Japanese
-Channels: Stereo
-Sample rate: 48000 Hz
Stream 2
-Type: Subtitle
-Codec: SubStation Alpha subtitles (ssa)
-Language: English
-Description: English subtitles
In handbrake, I am using the normal preset.
Video:
Anamorphic: Strict
Cropping: Automatic
Variable Framerate
Constant Quality: RF:20
Audio:
1 Japanese (aac) (2.0 ch)
Audio codec: (faac)
Mixdown: Dolby Pro Logic II
Samplerate: Auto
Bitrate: 160
Subtitles:
1 English SSA
Burned In
Default
I have tried converting on my 32-bit and 64-bit PCs, both choke on the file and fail. The file has been tested and works fine as MKV. After repeatedly trying to fix the problem, I suspect the conversion is choking on hardcoding the subtitles. Converting the video with no subtitles does work.
Please, no suggestions of other programs unless they will fix the problem; I have already tried multiple programs, all yielding the same results. Is there any way I can toggle a setting or something to fix this?
Have you tried latest handbrake 0.9.9? Or beta versions from http://handbrake.fr/nightly.php
If you suspect the subtitles perhaps try to drag them into Subtitle Edit and see what Tool -> Fix common errors reports.
Lossless conversion with Handbrake?
By WBFAir in forum Video ConversionReplies: 69Last Post: 1st Sep 2013, 17:35 -
Why Handbrake and FFmpeg MP4/x.264 conversion speeds are so different?
By falco2000 in forum Video ConversionReplies: 4Last Post: 30th Sep 2012, 09:10 -
720p conversion of PAL 25fps to NTSC 59.94fps using Handbrake?
By texas1 in forum Video ConversionReplies: 7Last Post: 29th Jan 2012, 11:06 -
Handbrake: Output picture size after conversion differs to source
By RF264 in forum DVD RippingReplies: 5Last Post: 11th Mar 2011, 07:02 -
Handbrake or WinFF conversion with no loss of video quality?
By sideshowmel in forum Video ConversionReplies: 0Last Post: 13th Jan 2009, 18:15
