Good evening to all you,
I'm a newbie in video editing and I would post a question about a simple video conversion.
I took a video with my Canon photo-camera, it was a MOV. So I converted it to MP4 in order to watch it on my TV set.
I used Freemake Video Converter.
The conversion was successful, but it flickers on the first frame.
I tried more and more and changed many of the converter options.
I achieved something good changing the video codec from H.264 (the converter default) to MPEG4.
I don't understand if I have to discard H.264 or there is some other workaround.
Is there somebody that can give me some hints?
Sorry for my poor English. Here are some technical data:
--- SOURCE FILE ---
Quick Time Video
size 58,8 MB
19 seconds long
1280 x 720
29 frames/sec
--- CONVERTED FILE ---
MP4 Video
size 8,24 MB
19 seconds long
1280 x 720
29 frames/sec
I also attach the (badly) converted video
Thanks much
Thanks for your answer Baldrick,
OK, I'll install Handbrake to try a new conversion (I'll do that tomorrow
By the way, the original MOV file was correctly viewed in Windows Media Player.
See you later, Baldrick -
Hello everyone,
I have some news about my original thread. I discarded the Freemake converter and mounted the Video-to-video converter (free). Now the conversion works good and I can play the MP4 movies without frozen frames
I first tryed convertion with these options:
* MP4 Movie
* Lenght: 19,886
* Quality: custom
* Video codec: mpeg4
* Video size: original
* Video aspect: auto
* Video bitrate: 1024
* Video framerate: auto
* Audio codec: aac
* Audio bitrate: 128
* Audio sample rate: 44100
* Audio channels: 2 stereo
* Sync A/V: no
* Audio stream index: default
* Volume: 1/8
* Target filesize: unlimited
* Two pass encoding: no
* Deinterlace: no
* Keep aspect: yes
And then I got a 2,86 MB file
Changing the Quality option to "Same as source" I got a 53,7 MB file
Changing the Quality option to "Lowest" (which also moves the Video and Audio bitrates to 1732 and 64, respectively), I got a 4,37 MB file
And finally, changing the Quality option to "Highest" (which also changes the Video bitrate to 10400), I got a 25,0 MB file
Well, I'm absolutely a newbie in video processing, so I've a poor comprehension about those options. Playing the converted files, I discarded the "lowest" and the "custom" files: artifacts are too much noticeable.
But I found it difficult noticing any differences between the "highest" and the "same as source" files. And between these and the original MOV file. By the way there is a very big difference between file sizes:
"highest" is a 25 MB file
"same as source" is a 54 MB file
the original movie is a 59 MB file
I would ask you if there are some tips which can help me in choosing the "quality" option in this conversion (and in the future ones, also).
Furthermore, are there some options (other than the "quality" one) I can/have to change, to get good MOV to MP4 conversions?
Thanks everybody for your care
Now I append some other technical info about the original MOV file:
--- Source info ------------------------------------------------------------------------------
- General
- Complete name : MVI_3112.MOV
- Format : MPEG-4
- Format profile : QuickTime
- Codec ID : qt
- File size : 58.8 MiB
- Duration : 19s 887ms
- Overall bit rate : 24.8 Mbps
- Video
- ID : 1
- Format : AVC
- Format/Info : Advanced Video Codec
- Format profile : Baseline@L4.1
- Format settings, CABAC : No
- Format settings, ReFrames : 1 frame
- Format settings, GOP : M=1, N=15
- Codec ID : avc1
- Codec ID/Info : Advanced Video Coding
- Bit rate : 23.2 Mbps
- Width : 1 280 pixels
- Height : 720 pixels
- Display aspect ratio : 16:9
- Frame rate mode : Constant
- Frame rate : 29.970 fps
- Color space : YUV
- Chroma subsampling : 4:2:0
- Bit depth : 8 bits
- Scan type : Progressive
- Bits/(Pixel*Frame) : 0.841
- Stream size : 55.1 MiB (94%)
- Language : English
- Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
- Transfer characteristics : BT.709-5, BT.1361
- Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
- Audio
- ID : 2
- Format : PCM
- Format settings, Endianness : Little
- Format settings, Sign : Signed
- Codec ID : sowt
- Bit rate mode : Constant
- Bit rate : 1 536 Kbps
- Channel(s) : 2 channels
- Channel positions : Front: L R
- Sampling rate : 48.0 KHz
- Bit depth : 16 bits
- Stream size : 3.64 MiB (6%)
A MP4 Simple Conversion
By kerb in forum Video ConversionReplies: 7Last Post: 27th Sep 2011, 11:24 -
I'm scratching my head - I just want to do simple video conversion?!?!
By Matt_C in forum MacReplies: 6Last Post: 9th Jan 2011, 21:26 -
simple blu-ray conversion
By cynikalhedonist in forum Authoring (Blu-ray)Replies: 16Last Post: 10th Dec 2010, 00:15 -
Simple H.264/AAC editing and conversion ?
By Norio in forum Video ConversionReplies: 5Last Post: 1st May 2010, 15:53 -
Simple .mov to Flash Video conversion for OSX
By pakawufs in forum MacReplies: 1Last Post: 22nd Oct 2009, 08:38
