  1. Hi there, first time post. I could really use a software recommendation, allow me to explain what I am trying to do.
    I need to convert the size and/or format of many videos at once, while adding a watermark to them. HOWEVER, I do not want the watermark to be on the entire video, I want it to come and go in maybe three or four sections of the video. All of the videos I will be converting are of different lengths, ranging from 30 seconds to 4 minutes.
    I have been using AVS Video Converter for this task, which is ALMOST perfect. It converts size and format perfectly, and has an editing section where I can place the watermarks. However, I have to re-create the watermark via their text editor for every single use. For 100 videos this is 300 - 400 times, which is quite time consuming. They don't have a copy and paste feature, which is ALL I would need to be satisfied with that software.
    Does anyone have any suggestions? I used to use a script inside of VirtualDub, but it didn't support all of the formats I needed to input, such a .flv.
    Any help is greatly appreciated! Cheers.
  2. Member olyteddy's Avatar
    Dec 2005
    Could you do the watermark as a .PNG graphic file?
