Hi.I am transfering old VHS on my cpu. The image is perfect but the sound is not good : I hear voices normally, but at the time the crowd starts to applause (it's a TV quiz), the sound is all but good. There is a lot of distortion.
I had the same problem when I played a humour show on DVD in my cpu and tried to acquire only the sound. The same thing happens : voice is ok, crowd applausing makes distortion.
I am pretty sure it's something easy to fix, but I really don't know what to do.
Thanks for your help and sorry for my bad english.
What is your video capture device? Attach a sample of the audio (or video+audio). Sounds like it's getting too loud and peaking.
Hi !First, thank for answering, I appreciate that.
I use DVD Maker USB 2.0 (http://us.kworld-global.com/main/prod_in.aspx?mnuid=1306&modid=10&prodid=104&flag=1)
I included a short sample of the voice and then the crowd.
Let me know if you know how to fix that. I know i'll feel numb after understanding what's wrong...
Okay, no clipping. There is a peak at one point, but it's when the host is yelling.
But what you posted is not what unprocessed VHS sounds like. Is this really what the captured file sounds like without further processing? The hollowness during the applause sounds like there was noise reduction applied.
Is the DVD Maker USB 2.0's sound connected to your PC's sound card? Find the software for that and disable any Digital Signal Processing features. -
You were absolutely right ; i unchecked the auto processing.
Told you it was going to be à rookie mistake !
Thank you so much vaporeon800 !
Sound problem during vhs capture
By monks19 in forum Capturing and VCRReplies: 13Last Post: 6th Jan 2013, 13:26 -
Where can I download stadium crowd noise sound effect from?
By Vanster in forum Newbie / General discussionsReplies: 10Last Post: 9th Aug 2011, 19:02 -
Easycap USB adaptor and Windows Vista Ultimate - Sound distortion problem
By Eric544 in forum Capturing and VCRReplies: 4Last Post: 10th Jun 2011, 16:52 -
Sound distortion when play CD on Magnavox ZV457MG9A
By AliceWonder in forum AudioReplies: 1Last Post: 12th May 2011, 12:16 -
vhs video capture bad sound
By lulu15 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2011, 21:59
