I am recording a live show music. What do I need to buy to get a clear audio recording?
Currently I do not get a clear audio, I was standing next to the next speaker as well.
Better to ask at http://www.taperssection.com and http://recording.org/forum.php
I am sure that there are people with audio knowledge here but do clarify your goal.
Are you just recording audio or is the audio in your video recording not clear.
What I can tell you that standing next to a speaker is possibly the worse place you can be. Too much feedback. -
Yes, the people who tape concerts as their hobby will have the best information.
Without going into detail, you'll need: good microphones, good preamps, a good recorder and a good way to mount them all in a good place without being bothered by security or other audience members. You'll also have take measures to deal with the fact that sound pressure levels at concerts is usually well above the range that most mic-preamp-recorder chains are comfortable handling. In other words, what works well for recording bird sounds in the wild will probably sound distorted and horrible at a concert.
Advice for recording live music with Canon Vixia HF M41
By gsscooter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th Dec 2011, 22:55 -
Tips on recording live Audio properly (help is very much needed.)
By rainrainrain in forum AudioReplies: 10Last Post: 28th Apr 2011, 12:02 -
Can anyone recomend audio recording software for background music?
By bweath in forum AudioReplies: 4Last Post: 18th Jun 2010, 05:12 -
Making an old dvd recording clear
By cyber-junkie in forum EditingReplies: 11Last Post: 10th Jan 2010, 03:15 -
Screen recording is not very clear for characters
By George2 in forum Newbie / General discussionsReplies: 31Last Post: 1st Jun 2009, 09:02
