Please correct me if I'm wrong here:
Demuxing the DTS-HD MA audio track from a Blu-ray and remuxing with something like mkvmerge is a lossless transfer of the original file. It does not need decoded if it's just being remuxed.
Converting the audio to ac3 with eac3to "movie" 1) 3:audio.ac3 will not be able to decode the lossless portion but should correctly decode the DTS core and encode to ac3.
As long as you are ok with the DTS core only being used for the AC3 conversion there is no reason to use something like totalmedia for decoding the HD MA track.
Is all of this correct?
I believe that's all correct. Without a pay-for decoder like ArcSoft the only way to keep or use the DTS-HD track is to remux it.
And then you'll still only get the DTS core unless your player/receiver supports DTS-HD.
eac3to: DTS-HD MA (Arcsoft) -> W64, clipped the center channel
By Asterra in forum AudioReplies: 1Last Post: 19th Apr 2012, 02:37 -
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 11:35 -
ReMuxing Elementary With DTS
By DeathStalker77 in forum Authoring (DVD)Replies: 2Last Post: 28th Aug 2011, 06:20 -
eac3to with HdBr Stream Extractor Decoding DTS-HDMA?
By MACCA350 in forum Blu-ray RippingReplies: 8Last Post: 17th Aug 2011, 01:01 -
eac3to conversion- thd->dts
By runLoganrun in forum AudioReplies: 0Last Post: 16th Dec 2008, 13:47
