I am having a difficult time transferring HD video from my Sony HDR-HC7. I have purchased a fire wire card to work with i.LINK and tried to capture the video, even using Sony Vegas, but it does not work consistently. Out of 20 times, it has worked
only once or twice and always errors out.
I am able to transfer via A/V capture card to USB, but I DO NOT think I can get HD video with this, only analog with low quality. Am I correct?
Is there anyone using the Sony HDR-HC7, and is able to capture HD video without problems. Can you recommend your setup?
I am using Windows 7 64 bit 0/S.
	There's a program out there windv I think for doing dv transfers. Firewire is the only way to go for dv on tape. Unless you have a camera with a memory card firewire ensures a bit to bit transfer.
 Edit - just checked the link myself and yes windv is for transferring dv files.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  Import/Capture Video from MiniDV - Audio is ChoppyBy Guy Leatherman in forum Capturing and VCRReplies: 17Last Post: 21st Oct 2010, 12:35
  DV capture from sony HDR-HC9E to AVI thru virtualdubBy one1 in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2010, 21:50
  Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolutionBy UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
  Sony HDR-HC3 HDV CaptureBy plugh in forum Capturing and VCRReplies: 8Last Post: 10th Aug 2009, 00:15
  capturing on sony hdr-hc7 NTSC Tape / PAL Camera issue ?By DKmickey in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Feb 2009, 15:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
