I cant install the latest version of IMGBURN , I keep getting an error message claiming "your version of INTERNET EXPLORER is INCOMPATIBLE .....Please install IE 7 or higher.
I have AFAIK disabled IE7 from my PC and am using FIREFOX. Can anyone help me out and help install the latest version of IMGBURN
The last time we got a weird "I can't download ImgBurn" post, the guy who posted admitted that he wasn't using the official link. Go to the Tools/Software and Downloads section in the left column here and search for ImgBurn and then use one of THOSE links instead. Unfortunately there are a lot of fake ImgBurn links and maybe you got one of those.
Or just click the red link from either your post or jman98's reply.
But I wonder. The latest version of the program is riddled with adware which tries to install itself when you install the program. Maybe that part of the installation is looking for specific (or later) versions of IE. You do not disable IE per se but rather choose a default browser. IE is still lurking in the background.
I still do not see why you could not install it as long as you are carefull with the installation process and choose not to install the adware rather than just blindly say 'yes' to everything.
Also read here:
https://forum.videohelp.com/threads/356775-What-s-Happened-To-Imgburn
Failing that, from the same software link as above, if you do not need the latest version, just install the previous one which is adware-free. -
Lightning UK (ImgBurn's author) did apparently at least change the installation from what it originally was on the latest release so that it's more obvious that you are actually going to install adware and more obvious on how to not install the adware. The original release was strongly criticized for installing adware in a sneaky, reverse logic way, if I remember correctly. Users were asked something like did they not want to install the adware and they had to answer "yes" or they got it.
As per norm, you guys are SPOT ON, for some reason I had been guided to a spurious fake version.......shoukd have used the TOOLS section from the start, THANKS AGAIN!!!!
Why install? Just use it as portable. No adware, nothing in the registry, all settings in app folder:
1. Download the installer only from here - http://www.imgburn.com/index.php?act=download (use Mirror 7 - Provided by ImgBurn)
2. Open installer with 7-Zip (Ctrl+PageDown)
3. Copy everything except $PLUGINSDIR folder to a directory of your choice
4. Create a text file in that directory called ImgBurn.ini and paste the follow text:
5. Finally, launch ImgBurn.exeCode:[Settings] PortableMode=1 FILELOCATIONS_GraphDataFiles=.\Graph Data Files\ FILELOCATIONS_ImageFiles=.\Image Files\ FILELOCATIONS_LogFiles=.\Log Files\ FILELOCATIONS_ProjectFiles=.\Project Files\ FILELOCATIONS_QueueFiles=.\Queue Files\
Firefox 19.0
By RustyBob in forum ComputerReplies: 12Last Post: 5th Mar 2013, 17:11 -
Zoom FireFox
By jollyjohn in forum ComputerReplies: 3Last Post: 26th Sep 2010, 11:20 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 17:47 -
Firefox 3.5.4
By pepegot1 in forum ComputerReplies: 3Last Post: 26th Oct 2009, 07:47 -
Firefox 3.5.1 available for download
By pepegot1 in forum ComputerReplies: 4Last Post: 19th Jul 2009, 01:20
