Hi All,
Now that HDV and DV have almost disappeared, I thought I might try my luck at saving my Sony Z7HVRE for a while longer. Via the camera's HDMI output, I have hooked up the Z7 to an Atomos Ninja-2 field recorder.
On static shots the output looks fine on both the Z7 and the Ninja-2 screens, but when imported into FCP7 (I select 'yes' when asked if I want to change the sequence settings to the clip settings) any movement (pan or tilt, no matter the speed) gives the impression of jerkiness and juddering.
Z7 settings:
- Output HDV1080i
- Rec type Interlace
- Scan type 25
- Shutter 1/50
Ninja-2 settings:
- 1080i50
- Codec ProRes 422
or
Z7 settings:
- Output HDV1080i
- Rec type Progressive
- Scan type 25
Ninja-2 settings:
- 1080p25
- Codec ProRes 422
Panning and tilting on the Ninja screen is juddery - the same in FCP7.
On the Z7 (the little icon on the screen) indicates 1080i the entire time - even when switched to progressive25p in the menu, so I am of the opinion that the sole output from the Z7's HDMI is an interlaced signal.
If anyone has any ideas as to a work-around for this pair, then I would be most grateful to hear your views. I have a shoot on Wednesday and I may well take a Canon DSLR instead …
Thank you for your time.
George
might be a field order problem. switch top and bottom field first in the ninja and see if it helps.
Thank you for your reply.
I've had a good look around the Ninja-2 and I cannot find an option to change the field order ...
Now I hate Michael Bay - "Alien" Ninja Turtle movie for 2013
By yoda313 in forum Off topicReplies: 18Last Post: 2nd Jun 2012, 18:55 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Greetings from Video Ninja
By videoninja in forum Newbie / General discussionsReplies: 6Last Post: 12th Aug 2009, 10:55
