Results 1 to 17 of 17
    Oct 2006
    Malaysia
    Hello, I need help in making a videoclip. I am trying to make a music video. I have 5 different videos and I would like to combine all 5 into one scene, with each of the member in each separate video. I'd just wanna make it simple. The video would look like a cake cut into 5 squares, if you know what I mean.
    I can't live without my computer.
  2. I think the simplest way to do this is with a non-linear video editor, to stack the 5 clips on the timeline, then resize and/or crop each of them and change their location on the frame.
    Oct 2006
    Malaysia
    Originally Posted by codemaster View Post
    I think the simplest way to do this is with a non-linear video editor, to stack the 5 clips on the timeline, then resize and/or crop each of them and change their x and y coordinates or location on the frame.
    What is the name of the video editor?
  4. There are several non-linear video editors that can
    I would recommend using a non-linear video editor that has support for the type of camera that you use, so that you can just import the clips from the camera, and start editing. If you are not already using a non-linear video editor, you can try, for example, Sony Vegas, and install the trial, to see if it works well with the clips from the camera or cameras that you use. There are two free non-linear video editors, OpenShot and Cinellera, but I don't know if OpenShot can combine 5 clips into one scene, and I don't know if Cinellera can import from your camera or cameras.
  5. DECEASED
    Jun 2009
    Heaven
    ^ minor nitpick:
    codemaster meant CineleRRa
    http://cinelerra.org/
  6. Yes, Cinelerra. Or, more specifically, CinelerraCV, the Community Version, because it's much easier to install than Cinelerra from Heroine Virtual.
    Oct 2006
    Malaysia
    I can't open the xz file
  8. DECEASED
    Jun 2009
    Heaven
    So you still don't have 7-Zip
    Oct 2006
    Malaysia
    I do, but I still can't open it. Is there any other freeware that can combine several clips into one screen?
  10. Originally Posted by aruwin View Post
    Wax and Lightworks.
    Oct 2006
    Malaysia
    Wax and Lightworks.
    Is there a tutorial on how to combine multiple videos into one screen using lightworks? Could't find it on youtube.
  12. Originally Posted by aruwin View Post
    http://www.lwks.com/
    http://www.lwks.com/index.php?option=com_content&view=article&id=69&Itemid=192
    Honestly dude, if you couldn't find this on your own you'll never learn to use the program.
    Mar 2011
    Nova Scotia, Canada
    That's because cinelerra (and also openshot), while very good, is a linux program. You can't open a llinux tar file in windows.
    Mar 2011
    Nova Scotia, Canada
    Sorry, but I gotta agree with this.
  15. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Originally Posted by Hoser Rob View Post
    You can't open a linux tar file in windows.
    Say's who ??
    Sure you can.
    I have before in windows.
    It has been rarely needed but I have done it.
  16. Originally Posted by Noahtuck View Post
    Say's who ??
    Sure you can.
    I've done it many times too. 7-zip can open them and extract the contents.
  17. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Man, that LightWorks home page really pops and sells the sizzle. I'm gonna download and try it again.
    UPDATE: Nope, it's too weird still!!!!
