Hi anyone,
I made a custom directory with a customination of the component of file ffmpeg.
But now I need to build the ffmpeg.exe files under windows. In what way do I go?
Thanks!
you might want to look at one of the autobuild scripts out there, in example:
https://github.com/jb-alvarado/media-autobuild_suite
(or if you want to do build win32 binaries on linux: https://github.com/rdp/ffmpeg-windows-build-helpers)
ffmpeg.exe has stoped working
By downer in forum SVCD2DVD & VOB2MPGReplies: 33Last Post: 6th Aug 2014, 16:45 -
Looking for build script to statically build ffmpeg, mencoder, mplayer,...
By Selur in forum MacReplies: 8Last Post: 11th Sep 2013, 15:13 -
Need mencoder.exe and ffmpeg codecs
By swkenney in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2010, 19:41 -
I need a supported build of ffmpeg for Avanti 0.4.8
By flashandpan007 in forum Video ConversionReplies: 1Last Post: 23rd Jun 2010, 09:28 -
Addresssing Exception in ffmpeg.exe at C0F76
By bitbinder in forum ComputerReplies: 0Last Post: 15th Jul 2009, 16:34
