  1. Member will7370's Avatar
    May 2009
    At work I use a PC configured with Windows 7. I adjust Internet Explorer to fill half my computer screen, and another program to fill the other half. Internet Explorer will retain the width dimensions that I set it to, but it absolutely refuses to retain the height dimensions that I stretch it to. It always "snaps back" to half it's height when I refresh the program display.
    What causes this?
    How can I stop it so that it will just stay the way I set it?
    Any help of suggestions would be appreciated.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Win7 has many view options built-in (using Aero). Read more here: http://answers.microsoft.com/en-us/windows/forum/windows_7-desktop/split-screen-option...f-04af477f5cc5
    As to your specific issue, are you saving the window size? (Open a single instance, drag it to the size you want, close it). When you reopen it, it should be the size in which it was closed.
    Google is your Friend
  3. Member will7370's Avatar
    May 2009
    Thanks for the help! I'll give these a try.
