Results 1 to 18 of 18
What's your problem ?
You asked the question in your OP and you were given the answer. You appeared happy with the answer and the follow ups.
Then you ask the same question again.
Do you really expect a different answer ?
BTW IMO changing from 1080p to 720p is not, in itself, going to speed up the import of the TS file into Vegas. -
first things first, you don't "convert" a 1080p file to 720p, you re-encode the file to a lower resolution and the quality of the 720p will be dependent on both the codec used as well as the resize filter used, some resize methods will give a softer, blurrier output than some others.
to me it's silly to do the above and then import that into Vegas in order to do more editing and then another re-encode during the exporting of the finished file.
if Vegas is running slow either during or after the import into the timeline you should check to make sure you have enough ram, editing 1080p video in a pro caliber editor can require substantial ram.
your workflow should be import file into Vegas, do your edits, then export to the desired codec and resolution in order to minimize quality lose.
you may be tempted to convert the 1080p file to a lossless format prior to importing into Vegas but i would recommend against it. a 1080p lossless file would be huge and while it would reduce the amount of cpu power needed to import into the Vegas timeline and to edit it, a lossless file, due to it's inherent large file size would require more ram to import into the timeline and edit.
there's no such thing as a free lunch in video editing, either you need significant amounts of cpu power or you need significant amounts of ram, and more often than not you need both. -
where exactly do you see a mention that Vegas supports anything like that:
http://www.sonycreativesoftware.com/vegaspro/techspec
also, what you said doesn't make sense, you encode your 1080p file to mpeg-1 SD, load that into Vegas, edit it and before the final render you replace your mpeg-1 with the original? do you use Jack's magic beans to do this?
you would still need to unload your mpeg-1 from the timeline, load your source and redo the edits, unless you're claiming that Vegas would somehow remember the edits done to the smaller file and apply them automatically to the larger file, but that still requires significant amounts of time to trancode to mpeg-1, edit that file, load the original back into Vegas, have Vegas supposedly automatically apply your edits and then export the desired output.
again, there is no such thing as a free lunch, there is a basic underlying law of physics that says you can never get more energy from a system than you put in and realistically you can't even break even; this applies to all facets of life, all your suggestion does, if it would even work, is to add more work to what he wants to do. -
deadrats, it just works, Vegas can replace clip with another clip, it doesn't have to be even the same kind of clip, there is no magic involved, Vegas has no idea what's in the clip while editing, only we can see picture, so you tell Vegas to change the clip he takes all reference timecodes or whatever it uses as reference and applies it on the other clip.
Not sure why everybody is afraid of this swapping thing, anybody can test it himself. No unloading etc needed, just right click on video in project media, choose Replace, and browse for new video.
You can even do it hard way, save project, close project, delete proxy video, open project, Vegas will protest that original clip is not to be found, gives choices, you choose locate for file yourself and locate original. This I tested and worked but I would not recommend this one I guess.
EDIT: looking to give you some link I googled this, so this is literally third way to do it, Vegas calls it "Add as Take"
http://forums.creativecow.net/thread/24/871970Last edited by _Al_; 1st Oct 2013 at 01:05.
It works in Movie Studio 11 as well, (and probably earlier versions.) Right click on clip in project media window -> replace. But OP has already indicated he does not like correct answers if they involve Vegas.
ok, here's a question; with this proxy feature, if you have a large file, say 10gb and it takes a long time to import it into Vegas and load it into the timeline so you decide to use this proxy feature, you would still need to spend time creating this smaller proxy file, correct? you would still need to do all your edits to this proxy file correct? and then you guys claim that all you do is choose replace file but in order to replace the file with another file the one loaded into memory must be unloaded from ram, the new one still has to be imported and the saved edits you did have to be applied to the 10gb and then it needs to be exported using the desired compressor, no? you haven't saved yourself any time, if anything you have added more time to your workflow.
i'm going to download the Vegas 12 demo and test it out for myself, timing how long it takes to just load a large file into the timeline and edit versus creating a proxy and using the above method.
i just have to see this for myself. -
deadrats, you are correct in that the proxy process does not save any reencoding time.
Where it's useful is in complex projects with a lot of edits, rearranging, overlapping audio, effects, etc. One makes a proxy for a more responsive timeline and smoother editing. Small raster size, I-frame only files can make for a much more pleasant editing experience in situations where creative editorial will take up most of the time.
If one is simply cutting out large chunks and butting ends together it's probably not worth it.
Proxy editing (before it was even called that) was the standard offline-online workflow on the earliest NLEs (avid) because computers were simply not powerful enough to edit uncompressed. (And Hd space was over $1000/gig)Last edited by smrpix; 1st Oct 2013 at 09:51.
Converting 1080p video to 720p and 480p
By ROBO731 in forum Video ConversionReplies: 5Last Post: 11th Jun 2014, 14:17 -
simple way to resize video from 1080p to 720p
By snafubaby in forum Video ConversionReplies: 3Last Post: 28th Apr 2013, 20:51 -
720p video on a 1080p TV, and vice versa?
By sldvd in forum Newbie / General discussionsReplies: 15Last Post: 16th Jun 2011, 22:21 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23
