I have a bunch of home videos recorded on 8mm and Hi8 consumers camcorders that I have imported into my computer by playing it in a Sony TRV-120 D8 camcorder and capturing over Firewire with WinDV.
I want to upload a lot of this content to places like Facebook and SmugMug so I would like to deinterlace.
What would be a good option to deinterlace this with a pretty good quality output, keeping in mind the quality of the source material is only "ok". Main goal would be something that won't degrade quality any further and is reasonable simple to do, and will hopefully run at faster than 1x time. Core i7-2600 CPU, Radeon HD 4600 GPU)
Your source is now DV so unless you keep it as DV you will reduce the quality. That is inevitable.
You can import your DV into avidemux to convert to a distribution format. There are filters there to de-interlace.
Note that avidemux only accepts type-2 DV. If you created type-1 your will have to convert to type-2 before importing.
Of course there is also avisynth, which I am still learning but others can guide you. Avisynth, AFAIK, will only accept type-1 but there are many more filters to help retain the quality. -
Please post a short sample. 10 seconds of steady movement will be plenty. The chances are, since it's from a film source even if 8mm or Hi8, that it doesn't need deinterlacing but something else, field-matching and decimating or similar. If that's the case, then deinterlacing will cause the quality degradation you specifically said you don't want to happen.
It,s not film, it,s analog tape digitized to dvavi.
try vidcoder with detelecine and decomb set to default, deinterlace and denoise set to off.Last edited by aedipuss; 29th Sep 2013 at 19:44.
Do not deinterlace unless adding to Youtube/etc.
For home viewing, leave it alone.
Use Avisynth with QTGMC for the best quality.Want my help? Ask here! (not via PM!)
feeding videos from remote place to home
By Antiquescopes in forum DVB / IPTVReplies: 1Last Post: 15th Mar 2013, 08:26 -
How to archive best home videos?
By Seasonal in forum Off topicReplies: 1Last Post: 4th Oct 2010, 17:39 -
Restoring old VHS and Hi8 captured videos with Premiere
By alegator in forum EditingReplies: 1Last Post: 4th Oct 2010, 06:07 -
help with burning home videos to dvd
By ppalacios2 in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2010, 07:17 -
need to transfer videos from hi8 camcorder to pc
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2010, 18:42
