Hi, I'm doing some experimenting with ffmpegX to find the best encoding settings for a web service. I don't have too much command line experience, but my friend, who will handle the server side of the website, asked me to research video settings.
So my goal was to try many different settings with a GUI like ffmpegX and then give him to corresponding commands that he can use in Linux on the web server.
What I came up with from ffmpegX is this:
Code:date | /Applications/ffmpegX.app//Contents/Resources/pbcopy && printf "Encoding started on " && date && /Applications/ffmpegX.app//Contents/Resources/movtoy4m -w 1152 -h 672 -F 30000:1001 -a 16:9 -f -o raw -s /Users/Mike/Desktop/source_clip.MOV | /Applications/ffmpegX.app//Contents/Resources/x264 -v -A i4x4 -b 0 --qpmin 10 --qpmax 51 -B 3000 --me hex --threads 2 --level 51 --fps 30000/1001 -o /Users/Mike/Desktop/output_clip.video.mp4 - 1152x672 && printf "Encoding audio..\n" && /Applications/ffmpegX.app//Contents/Resources/movtowav -o /Users/Mike/Desktop/output_clip.wav /Users/Mike/Desktop/source_clip.MOV && /Applications/ffmpegX.app//Contents/Resources/normalize /Users/Mike/Desktop/output_clip.wav && /Applications/ffmpegX.app//Contents/Resources/ffmpeg -i /Users/Mike/Desktop/output_clip.video.mp4 -i /Users/Mike/Desktop/output_clip.wav -y -vn -f mp4 -acodec aac -ab 128 -ar 48000 -ac 2 -map 1.0:0.0 /Users/Mike/Desktop/output_clip.audio.mp4 && /Applications/ffmpegX.app//Contents/Resources/mp4box -fps 30000:1001 -add /Users/Mike/Desktop/output_clip.video.mp4 -add /Users/Mike/Desktop/output_clip.audio.mp4 -new /Users/Mike/Desktop/andrewClip1.mp4 && rm /Users/Mike/Desktop/output_clip.wav && rm /Users/Mike/Desktop/output_clip.video.mp4 && rm /Users/Mike/Desktop/output_clip.audio.mp4 && printf "Encoding completed on " && date && printf "\a" && printf "\n"
I'm having some trouble translating it to plain commands. Can you guys help me? What I don't get is why it outputs it several times instead of just once... Thanks for any assistance.
	It's impressive that a first post user is able to find these commands, as ffmpegX doesn't make it easy for you.
 What you see is not just the use of ffmpeg, but a series of commands from ffmpegX that use other tools as well. This may be quite inconvenient for your friend.
 The binary of ffmpeg that ffmpegX uses, was compiled in April of 2006. Your friend may want to run a newer, more up-to-date version of ffmpeg. Unfortunately, the syntax for these newer versions is a bit different. The abilities of newer versions allow ffmpeg to do more by itself without resorting to other tools.
 __________________
 I'll try to give a breakdown of your code below:
 ffmpegX uses the pasteboard to transfer commands between itself and the various tools./Applications/ffmpegX.app//Contents/Resources/pbcopy
 This will "print" the start time to the terminal or log.printf "Encoding started on " && date
 ffmpegX uses movtoy4m to shift the video in .mov files to a different format. It does so only for .mov files./Applications/ffmpegX.app//Contents/Resources/movtoy4m
 The video gets converted to H.264 AVC using an x264 binary./Applications/ffmpegX.app//Contents/Resources/x264
 This will "print" a note that it is starting to encode the audio separately.printf "Encoding audio..\n"
 The audio in .mov files also gets a special treatment: it is converted to .wav (PCM). I suppose this may be needed for the next step./Applications/ffmpegX.app//Contents/Resources/movtowav
 The audio for .mov files gets a normalization treatment. I suppose this has to do with volume levels./Applications/ffmpegX.app//Contents/Resources/normalize
 Finally ffmpegX calls upon ffmpeg to convert the WAV audio to AAC./Applications/ffmpegX.app//Contents/Resources/ffmpeg -i /Users/Mike/Desktop/output_clip.video.mp4
 MP4Box is used to mux the H.264 video and AAC audio into one file./Applications/ffmpegX.app//Contents/Resources/mp4box -fps 30000:1001 -add /Users/Mike/Desktop/output_clip.video.mp4
 Temporary files get removed.rm /Users/Mike/Desktop/output_clip.wav
 This will "print" the end time to the terminal or log.printf "Encoding completed on " && date && printf "\a" && printf "\n"
	Wow, thanks for the in-depth analysis. Yeah, I had to go through a few steps to find how to extract the commands from ffmpegX, using a clipboard logger. I did do some research
 I guess it's a bit more than just a dressed up ffmpeg, since it uses its own tools. Those might be difficult to replicate for me.
 We're doing a sports video analysis service, and the goal is to have users upload footage in various formats and to have our server convert them all to the same format, with the same resolution, and the same bitrate and framerate.
 From your explanation, that sounds like it might be tricky, since the tools, and I assume commands, used would depend on the incoming format. Would you have any tips on what the best way to go about this is, since the whole process has to be automated? Thanks again for your help.
	Give iFFmpeg a try. It allows 10 conversions in trial mode, but it is not too expensive to register.
 It will show the command line that it will use, before conversion, if set to do so in Preferences.
 As far as I can tell, it only relies on ffmpeg.
 It can use any of the more recent builds of ffmpeg.
 The approach is a bit different, compared to ffmpegX. It took me a while to get used to it, and there's lots more to explore for me in there.
  Help with avisynth crop commandsBy Bully9 in forum Video ConversionReplies: 9Last Post: 5th Dec 2012, 16:42
  seeing the commands ffmpegX sends to ffmpegBy cablet in forum ffmpegX general discussionReplies: 1Last Post: 6th Jul 2010, 17:02
  Are my audio commands are right?By php111 in forum AudioReplies: 0Last Post: 13th Mar 2010, 13:11
  DVD VM CommandsBy TonitoDJ in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2008, 10:55
  Question about certain dos commandsBy jimdagys in forum ComputerReplies: 35Last Post: 15th Oct 2008, 23:57
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
