hi every
I have a VCD and I want to detect what kinda chapter it has and which format, because it's very very WEIRD VCD , I have tried in my DVD Player (AIWA 370) and it play fine, but I couldn't play it in PC ,, I tried 10 or 15 Player softwares but none couldn't play it
it seems have 30 Chapter but each chapter is in seprate DAT file in MPEGAV folder and I even couldn't convert them with VCDGEAR or VCDCUTTER or anything else
Please somebody help me becuase its very urgent , I want to burn a same VCD like this
Thank you..
Is it a retail VCD or a burned VCD?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
If it has multiple DAT files, it is a multitrack VCD, not chapters.
Try extracting a CUE/BIN disc image with CDRDAO or CDRWin and then use VCDXRIP to extract everything.
You can use VCD Easy as a GUI to VCDXRIP if you don't like using command console tools.
Regards.Michael Tam
w: Morsels of Evidence -
thanks for your reply
actually I've burned a copy of retail CD, and do you know how I can play this CD on my PC ? and by the way the first track in MPEGAV (AVSEQ01.DAT) is just playing in XING MPEG Player but not other DAT File
With best Regards.
S. Mohammad Najafi
my PCs can't detect disc format of VCD from Thailand
By Foobar in forum Software PlayingReplies: 2Last Post: 6th Jan 2011, 10:10 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 16:21 -
PC can not detect Dv recorder
By dazedandamused in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Apr 2009, 18:45 -
LG DN788 not read VCD?
By joselect in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Nov 2007, 13:04 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
