Hi,
I hope somebody can help me. I downloaded a lot of subtitles online before and mux it with my movies. Now I want to edit these subtitles as it has added lines to it. So I want to check what are the movies I need to edit without extracting the subtitle for every movie just to check if I need to edit the sub.
What is the quickest way to view the subtitle in mkv from start to end of movie?
I use mpc & vlc for playback but it doesn't have an option to view the whole subtitle(none that I know of).Thanks.
Just name the subtitle as same as the movie,not sure if you mean to extract the subs from rar or from the mkv but you have to have the subtitles extracted and named as the movie if you want to view the subs,you can add subs to mpc-hc without renaming them but it's more of a chore.
Thanks for the quick response. I meant to extract the sub from mkv and check if I need to edit that sub.
Right now I just wanna see quickly what movies(mkv) in my library have added lines to its subs so I can edit it later. Is there any software that can do this?
Nope,you have to extract the subtitle to view it and edit quickly.
Quick edit MKV subtitle
By Chakabear13@yahoo.com in forum EditingReplies: 4Last Post: 21st Jul 2013, 08:22 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03 -
Which to Upgrade (video card/processor) to view 1080P MKV fine on AX3200?
By vmanthegreat in forum Software PlayingReplies: 21Last Post: 16th Mar 2009, 15:33 -
simple and quick way to convert DVDs -> .mkv
By Helios61 in forum DVD RippingReplies: 2Last Post: 9th Mar 2009, 12:44 -
What program to view subtitle files?
By andre477 in forum SubtitleReplies: 3Last Post: 2nd Nov 2008, 16:15
