  1. I have an .m4v file that I'm constantly having a problem with burning using MultAVChd.
    It has a frame-rate of 23.976. I use mkvtoolnix to change it to an mkv file, where the frame-rate remains 23.976.
    When I try to author and burn to disc using MultiavcHD (which uses tsmuxer), TSmuxer says "Frame Rate: not found" even though Multiavchd still shows 23.976. The resulting file shows a frame-rate of 25fps.
    Any ideas? Is there a problem with the header? Is there any way to change that without completely re-encoding?
    Here's the info on the initial file:
    General
    Complete name : enhanced_commentary.m4v
    Format : MPEG-4
    Codec ID : M4V
    File size : 4.83 GiB
    Duration : 2h 42mn
    Overall bit rate : 4 247 Kbps
    Encoded date : UTC 2013-08-18 23:12:27
    Tagged date : UTC 2013-08-18 23:13:35
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=80
    Codec ID : avc1
    Duration : 2h 42mn
    Bit rate : 4 092 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.185
    Stream size : 4.65 GiB (96%)
    Language : English
    Encoded date : UTC 2013-08-18 23:12:20
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 2h 42mn
    Source duration : 2h 42mn
    Bit rate mode : Constant
    Bit rate : 149 Kbps
    Nominal bit rate : 160 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 42ms
    Stream size : 173 MiB (3%)
    Source stream size : 173 MiB (3%)
    Language : English
    Encoded date : UTC 2013-08-18 23:12:21
    But once it hits tsmuxer:
  2. If it is iTune video stream then no wonder: almost all lack of proper video header, and there is no info on frame rate. TSMuxer as well any BR authoring program will fail with such stream.
  3. Originally Posted by noemi7 View Post
    So there's no way to fix it without re-authoring?
  4. I didn't find any program that really correct such problem. Suggested were ffmpeg, TSMuxer, and VideoReDo. VideoReDo author wrote me that he is going to make a tool for h264 header correction as there are more and more such faulty streams.
    If you want to author the stream, you would need to re-convert it (not re-author). This of course will degrade its quality. I keep mine until a tool is available.
  5. Thanks for the response. I tried those as well as several others. We'll see what happens I guess.
