Having problems with IMGBURN freezing midway through a DVD Burning session, it responds slowly and the locks the disck in the tray......Doing a quick search on the net it seems its a common problem. and that IMGBURN Is no longer a decent burning tool. SO can you learned chaps recommend an easy to use burning program that is as good as IMG used to be and also can be used by a numpty like meBTW my browser is Firefox and not IE.....
Freezing is not an issue with imgburn, something else in the system is the cause.
Review running system tasks
Run malwarebytes scan
Defrag the harddrive
Then consider changing out cables and drive used to burn
And include media brand being used, some are noted for issues. -
I did see some freezing with ImgBurn earlier this year.
It was not program related - the drive was dying.
OP: check the log, and watch closely how imgburn fills the program buffer and drive buffer. If both do not stay near 100% during the burn, the flow of data is corrupted or resources are being used somewhere else (like antivirus, antimalware or some other software). You can also see what programs run at start that aren't needed and turn those off. Many programs set themselves to run on startup that aren't needed (printer programs, search engine programs, etc) and can be turned off.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
How to obtain a tiny sample of an *.img file from a huge *.img file
By lousk in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 08:03 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Ripping with SHRINK then BURNING with IMG burn
By efiste2 in forum DVD RippingReplies: 10Last Post: 17th Apr 2010, 00:39 -
Feedback: vbulletin, [img][/img] tags not working.
By vhelp in forum FeedbackReplies: 5Last Post: 27th Jan 2010, 23:51 -
Burning .IMG Files to DVD
By niteghost in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2008, 18:13
