When I run (from batch script) a 2-pass ffmpeg conversion job then afterwards always *.log and a *.mbtree file remains.
I guess ffmpeg needs them as intermediate files between the 1st and 2nd pass.
So they are useless after exit of ffmpeg.
How can I tell ffmpeg to AUTOMATICALLY wipe them at the end of the 2nd pass?
Furthermore I wonder if there is (another) log file which show the exact command (with all parameters) of the last executed command.
Is there such a logfile or can I tell ffmpeg to create one?
The *.log file currently created does (for example) NOT show the audiooptions I entered:
... -c:a libmp3lame -b:a 148k ....
Neither the string patterns "148k" nor "libmp3lame" appears in the whole logfile.
Thank you
you can't you need to delete them 'manually' in your script.How can I tell ffmpeg to AUTOMATICALLY wipe them at the end of the 2nd pass?
about the log: no, clue never really locked into the logging option in ffmpeg, I normally want it to shut up unless there's an error.
What's the difference between 2nd pass and two pass in h.264 encoders?
By Stears555 in forum Video ConversionReplies: 1Last Post: 26th Sep 2013, 05:09 -
HCgui 2nd pass problem
By ks47 in forum Video ConversionReplies: 0Last Post: 8th Aug 2013, 21:03 -
How to continue with 2nd pass if you have .stats and .mbtree files?
By ad.vid in forum Blu-ray RippingReplies: 1Last Post: 21st Dec 2010, 13:28 -
2nd pass encode fail
By john920 in forum Blu-ray RippingReplies: 19Last Post: 18th Mar 2010, 06:58 -
ffmpeg log file is empty...
By sunburnt in forum LinuxReplies: 0Last Post: 24th Nov 2009, 18:39
