Is it possible to have a server to stream video files to different rooms of the house. There is no internet. If possible what hardware would I need to in order to make this possible?
When it sounds too good to be true, it usually is!!
A router (wired or wireless) can be used to set up a home network even without Internet service. Get Cat6 cables if you are setting up from scratch and are building a wired network. Computers connected via wired Ethernet need to have a LAN port. Wireless adapters or powerline adapters can also work for connecting computers to the home network but they do not work well in every situation. Sometimes the home's wiring isn't right for powerline, and sometimes there are too many walls between the router and the computer to get a good signal with a wireless adapter. You can use a combination of these technologies if using just one doesn't provide an adequate solution.
Sort of obvious, but you need a PC or something like a WDTV box in each room and plugged into the LAN cable. You set up the server drives to be shared and they will show up on each PC as a network drive. I go one step further and use a WOL (Wake on Lan) program to turn on the server so it doesn't run 24/7. http://magicpacket.free.fr/ The server is set to timeout and go to 'sleep mode' automatically after 30 minutes of idle time.
I've never had much luck with wireless streaming, but it should work. Most newer routers are 'N' capable and they should have plenty of bandwidth for video streaming. -
Thank you guys.
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 17:25 -
Home server/Networked HDD
By OverrRyde in forum Newbie / General discussionsReplies: 16Last Post: 14th Jun 2011, 21:08 -
Rip to central server on my home network and stream to TV or computer
By RJC5XTC in forum DVD RippingReplies: 1Last Post: 13th Dec 2010, 21:03 -
home server port forwarding
By gooberguy in forum ComputerReplies: 6Last Post: 17th Feb 2010, 13:54 -
Need advice on setting up a home media server
By jamietallman in forum Video Streaming DownloadingReplies: 2Last Post: 7th Jan 2009, 01:25
