I have tried to use the new Sony software as suggested on this forum but something is wrong
I have 5 m2ts files I wish to record in high quality. On a std DVD they would take up 5.4GB of space so I would need to shorten the files to fit them on a std DVD. HOWEVER when I use the software to try and record to Blu-ray disc I am very surprised
The size of the 5 files is only 2.23 GB !! Surely if I want higher quality on Blu-ray the files should be bigger unless of course it is the Sony software because their idea of Blu-ray quality is only 50i/25p and I am not sure but is this LESS quality than a std DVD disc ?
I would really appreciate it if anyone can help me to make high quality recordings from m2ts files than a standard DVD disc
many thanks, Rob.
	You could always burn as data to a double layer dvd. Verbatim brand would be the best discs available to you. Use ImgBurn for the actual burn to the disc.
 If you want the m2ts files as data on a blu ray, ImgBurn can do this also. What are you using for playback?
 If you want the m2ts files as blu ray video format, on a blu ray disc, you might want to use MultiAVCHD to make a menu to select each one. By the way, just since they are m2ts format now, does not mean that they are necessarily compliant to the specifications needed for blu ray video. They may, or may not need to be re-encoded.
	The descrepancy is likely in the output type you are choosing. If you are choosing "DVD" format, then the source files get converted to DVD spec mpeg2 (thus they get bigger). Output type (ie: DVD or Blu-Ray) and disc type are two different things.
 Set the output to Blu-Ray and burn to whatever type disc is needed to hold the file size (ie: DVD SL, DVD DL, Blu-Ray, etc.).Google is your Friend
	How about a bit more information like what is the name of the " new Sony software" and what are the settings you use. Then someone might be able to work out what is going on.
 My speculation:
 It sounds like you are authoring a DVD so in the process of DVD authoring (instead of just treating the DVD medium as data) the quality is reduced to 520p which is the DVD standard. If you burn as data then whatever the file resolution is to start with remains just as if you copied onto a memory stick.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	In addition to the other information requested, what is the running time of the original files? Comparing file sizes between two completely different formats is too ambiguous on its own.
  how to make BD Video disc using m2ts filesBy vikas.babu in forum Authoring (Blu-ray)Replies: 6Last Post: 20th May 2010, 02:49
  Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p fileBy SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57
  How Do I Keep The Amazing Quality When Converting PlayTV .M2TS Files?By ltd. in forum DVB / IPTVReplies: 4Last Post: 18th Nov 2009, 05:53
  M2TS files in AVCHD on disc - Error: 80029946By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 22nd Jun 2009, 08:44
  How to edit Sony m2ts files to burn to blu ray disc.By tchambers in forum Authoring (Blu-ray)Replies: 23Last Post: 11th Nov 2008, 23:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
