I'm trying to convert my Blade 2 avi into vcd format but TMPENG (spelling) and Xing won't open the file for conversion. I can play the movie just fine on Windows Media Player Though. I have 2 files for Blade 2. Each is about 150 mb. Another program i used said the audio stream wasn't supported. (i forgot the name of the program because i deleted it in frustration). What do you guys think I need to do because none of the programs I've tried can support converting the file yet?
sounds like a DivX file with avi extention. You need to look to the left and look up how to convert DivX to vcd.
May the force be with you. -
youve got to rip the sound first, look trough the howtos to find out how to do that
Ah, I think I seen that, was it Vdub that complained ?. I think I just saved out another copy using streaming. The audio was not changed, Vdub said "0" seconds out of sync
You do need the codec installed to use those programs though, I guess you have those.
So try again with Vdub, You don't need to save out the Audio. Load it in to Vdub 1.49, do a "Scan Video stream for error's" set audio and video to streaming and "save as" save out blade1-fix.avi and use that with TMPGEnc
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 11:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 17:41 -
Converting .mov or .avi to flv does not work
By Alainb2809 in forum ffmpegX general discussionReplies: 22Last Post: 11th Oct 2010, 14:33 -
What is a good AVI joiner (freeware I hope) for when VDub won't work??
By Lolipop Jones in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2010, 10:52 -
Help with converting BBC HD Stream to DVD (Normal methods won't work)
By Killer3737 in forum DVB / IPTVReplies: 3Last Post: 30th Jul 2007, 10:23
