Hi.
Downloaded VirtualDub after reading its very good reviews.
Wanted to edit a 1 hour avi video of 750 MB.
Extracted a 5 minute clip from it.
Saved size of the clip was 1.2 GB !
What am I doing wrong?
Regards.
Amer
Results 1 to 14 of 14
Did you set a codec to compress to in video/compression ?
If you don't set anything it defaults to uncompressed - and it can be big, as you see.
On the other hand, if you want to use the file as-is (without re-compression), set video/direct stream copy. -
Virtual Dub saves video by default as uncompressed.
Choose a codec from the 'compression' setting under 'Video' -
Hi.Thanks guys for the help. This solved my problem.
Just one question... if we use the Direct Stream Copy option, will the saved clip be identical in quality as the original file?
Regards. -
Thanks.
Direct Stream Copy worked perfect and created small size clips of identical quality.
Now, how to join the cut clips?
Joining two clips of 6 MB and 55 MB has resulted in a file size of 370 MB. I chose the Direct Stream Copy option.
Appreciate your help. -
That, I believe, would only work if both clips have completely identical properties.
You will have to manually choose a compression codec if you want a smaller file. -
I also tried the compression options under video (Normal Recompress) and also under Compress >> ffddshow video codec.
But same result (huge file in gigabytes).
Thanks for help. -
Are the two clips from the same source video? If not then you have problems and one will have to be reencoded so it has the exact same properties as the other. If they came from the same video joining them without ballooning the size should be easy. In fact, if from the same video you can cut in such a way that they're joined to begin with.
Others beat me to it.
The two clips have been cut out from the same source file. So everything should be identical, including frame sizes.
"...If they came from the same video joining them without ballooning the size should be easy. In fact, if from the same video you can cut in such a way that they're joined to begin with....."
Can you please guide me how can I do both the above options?
Regards.
(p.s. I could not find x264 or xVID in the list of codecs under Video >> Compression). -
If you are doing this from the same video, it's easier just to cut out the parts that you don't want and save as one file. If you choose "smart rendering" you will get frame accurate editing. Everything will be copied like with direct stream copy but it will be re-encoded where the cuts are made. You will need to use the same codec as the original file.
If you wanted to be creative, then you could put fades between the cuts using the fill filter in blend mode and using the curve editor but that is probably another lesson for a new Virtualdub user.
virtualdub can't seem to decode h264 properly
By muffinman123 in forum Video ConversionReplies: 8Last Post: 19th May 2013, 16:29 -
Editing Lagarith AVI in VirtualDub
By HDClown in forum EditingReplies: 2Last Post: 25th Apr 2010, 21:20 -
editing mp4/flv files from youtube in virtualDub
By tolland in forum EditingReplies: 2Last Post: 16th Nov 2009, 16:50 -
VirtualDub cannot properly load H.264 Lossless video from AVI or Avisynth
By Jedi787Plus in forum Video ConversionReplies: 1Last Post: 14th Oct 2009, 21:38 -
Avi files not running properly
By Skyline in forum Newbie / General discussionsReplies: 6Last Post: 25th Dec 2008, 09:22
