Hi Guys,Previously i use avisynth to load video just fine. Now i upgrade my system to Windows 7.
Here what i do.
-Install latest CCCP
-Install Avisynth 2.5.8
The video freeze for a moment at the start and then a few second it was ok.
After that i install latest ffdshow, still same problem. I'm using the same script as previously while i on XP.
Here what happen to the video when i load the script in my mpc, http://s12.postimg.org/y4eump3bh/fma.png
And here is the code itself
Code:DirectShowSource("[Eclipse] Full Metal Alchemist Brotherhood - 01 (1280x720) [70C1405D].mkv", fps=23.976, convertfps=true) trim(1414,3567)
Any help is much appreciated. Thanks guys.![]()
1) That MKV probably contains H264 video, so you could use FFMS2 instead of DirectShowSource
2) Windows 7 is VERY different from XP, you'll need some time to learn many/most/all of the workarounds for its issues
3) BEWARE: https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)Last edited by El Heggunte; 25th Sep 2013 at 12:00. Reason: add _
Thanks for replying.I just try FFmpegSource2 script. here what i get when loading the video,
LoadPlugin: unable to load "ffms2.dll"
any idea?
Thanks -
just find the solution..i just install Haali Media Splitter and the video load.. many thanks..
Avisynth problem with VirtualDub
By shun in forum EditingReplies: 2Last Post: 2nd Sep 2013, 21:31 -
AviSynth Stack question Playback multiple videos with third video audio
By oroboros74 in forum EditingReplies: 17Last Post: 6th Nov 2010, 18:57 -
W7 + AviSynth + VC-1 = problem?
By follz20 in forum Video ConversionReplies: 5Last Post: 5th May 2010, 12:16 -
Avisynth video playback twice as fast
By honza.v in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 08:58 -
AviSynth Script Problem
By Eva-Unit01 in forum EditingReplies: 21Last Post: 29th Dec 2009, 12:00
