Hello
I would like to invert telecine of an original 25p source converted to NTSC with 3:2:3:2:2 pulldown.
Here is the code I wrote:
However TDecimate() removes some frames that are not duplicates on one hand and leaves some duplicate frames on the other hand. I'm wondering if there is a better way to retrieve the original 25p source without duplicates or missing frames.Code:AssumeTFF() TFM() TDecimate(mode=2,rate=25) AssumeFPS(25)
Here you can have a look at a short sample of the video I'm working on:
http://www.mediafire.com/?2v3jb55nyr9e5zu
Any advice will be appreciated.
Thank you in advance
Max
Results 1 to 20 of 20
It worked pretty well here. I saw only saw one duplicate frame in the 263 frame result. The d2v file doesn't match your m2v file. Try rebuilding it.
Try TDecimate(cycle=6, cycleR=1). That will give you 24.975 fps with no duplicates or drops. Ie, the source was slowed to 24.975 fps then went through straight 3:2:3:2:2 pulldown to create 59.94 fields per second.
Thank you for your answer.
I realized that I posted the thread in the wrong place.. I thought I was posting it in 'Video Conversion' section which seems more appropriated.. but I failed at some point.
I tried to rebuild and to use TDecimate(cycle=6, cycleR=1), but there are still some drops. For example between frame 831 and 832 in this new sample:
http://mathmax.mynetdomain.de/tdecimate.rar -
You're going to have to face the fact that decimation like this may never be perfect. Especially in a shot like that with little motion and a lot of noise.
You're lucky in that your video has numbered frames. You can examine the long run frame count to determine what the final rate should be. The difference between 24.976 and 25 would be 1 frame out of every 1001.Last edited by jagabo; 25th Sep 2013 at 20:51.
ah you're right. But that not exactly 1 frame out of every 1001.. sometimes between every 990-1000 frames (I look at the video after applying your script). Strange. Anyway, my best chance may be to look at the part around every 1000 frames and to add them manually, right?
See if this works. I'll let you do the counting:
TFM()
TDecimate(m2PA=True,maxndl=6,Mode=2,Rate=25.0)
If that's no good, then you can try bobbing it and letting SRestore do the decimating:
Yadif(Mode=1)#or the better QTGMC
Srestore()
Both give back 25fps which may be the correct framerate for this one.
MPEG2Source("sample.d2v")
AssumeTFF()
TFM()
AssumeFPS(25)
I guess you know that AssumeFPS line changes the length and throws the audio out of synch?
I checked carefully. This one is perfect !TFM()
Well.. there was only one mistake in the whole clip.. but that was because one frame was missing in the original pulldowned clip (the timecodes show that one frame was droped).
Thank you so much for your help jagabo and manono!
If you're a perfectionist/masochist and the pattern is consistent throughout, it's also possible to reverse it manually, but a longer sample is required to see a repeat in the pattern. (More than 1000 frames, I guess.)
Err, the camera is moving for 90% of the clip. And shouldn't the grain actually aid in differentiating the correct original frames since it's from the source and not the converted medium? -
I am.. but well, since I got a solution to do this automatically, that's enoughIf you're a perfectionist/masochist...
I'm wondering why the source is 25p originally. Isn't it strange that the original source is not interlaced? Or do you think it was interlaced and then half of the fields were dropped before pulldown? -
Thank you. I compared with another concert, and the pitch is the same. So probably the tempo was changed when converting from 24fps to 25fps without altering the pitch.
Sony Vegas Pro 11 Video Frames Gone Wrong
By Voelkerizer in forum Newbie / General discussionsReplies: 12Last Post: 16th May 2013, 12:03 -
VP8 adding frames, what did I do wrong?
By Selur in forum Newbie / General discussionsReplies: 8Last Post: 12th Apr 2012, 14:52 -
Question about the Right Use of tdecimate
By Womb4T in forum Video ConversionReplies: 29Last Post: 20th Nov 2010, 23:56 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 18:32 -
Silent frames and/or wrong clip start with Movie Maker
By fvisagie in forum EditingReplies: 0Last Post: 18th Aug 2009, 08:55
