Hello guys, I am using Media player classic along with LAV filters and MadVR settings like suggested in one of the sections of this forum. However, although the video quality is amazing, I have always whined about not being able to get a smooth playback, which considerably increases the joy of watching high definition stuff like 1080p MKV files. Any help is much much appreciated.
Results 1 to 13 of 13
Are you sure it's not your monitor? I have some HD vids that just wouldn't play smoothly but after plugging in my HDTV instead they're fine, I came to the conclusion the monitor is not capable of displaying that resolution at that framerate smoothly.
OK, thanks, but, The yellow icon of the program is there, but when i play videos it doesn't change to green as if it doesn't detect the playback. I am using MadVR+Lav filters as said earlier. What should I do now? Thanks for your help @jagabo
Then, is your notebook graphics card equivalent to a GTS 440, or a GTS 450 or better? When I looked at MadVR a couple of years ago, a GTS 440, or a GTS 450, or better was recommended for GPU assist when using its higher quality settings. People with only a GTS 430 had problems with stuttering playback. That is when I decided MadVR was not for me.
It's almost certainly a hardware issue. Most likely related to GPU processing. Guides are just that, guides. They don't work for all hardware combinations.
Try reading or posting here: http://www.avsforum.com/forum/26-home-theater-computers/1357375-advanced-mpc-hc-setup-guide.html
And when you find out what you are doing wrong, please come back and enlighten us.Google is your Friend -
How to do smooth effects ?
By ratmoonser in forum EditingReplies: 20Last Post: 26th May 2013, 21:37 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 14:14 -
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 16:57 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 11:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 22:41
