Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
  1. Originally Posted by El Heggunte View Post
    ^ Well-spotted, jagabo
    So I had to give a try to yuv2lav (from the MJPEGtools package),
    and probably it'll be as good ( or bad ^.^;; ) as Mencoder for the OP
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    File size                                : 13.5 MiB
    Duration                                 : 2s 833ms
    Overall bit rate                         : 39.9 Mbps
    Writing application                      : mjpegtools-2.0.0
    Video
    Format                                   : JPEG
    Codec ID                                 : MJPG
    Duration                                 : 2s 833ms
    Bit rate                                 : 39.8 Mbps
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 30.000 fps
    Chroma subsampling                       : 4:2:2
    Bits/(Pixel*Frame)                       : 4.323
    Stream size                              : 13.5 MiB (100%)
    EDIT: No, the result has the color channels swapped
    Heggunte please help me: I have download the mjpegTools 2.0.1RC1 and I have use this commandline:
    yuv2lav c0020.mxf -o testout.avi
    but strangely when I press the Return it don't do nothing and waith for a press-key
    when I press a key on the keyboard it returns: .. could not readyuv4mpeg reader
    So what I have to do for converting .mxf to .avi/mjpeg with Mjpeg tools?
    Thank you
  2. Originally Posted by El Heggunte View Post
    Format                                   : AVI
    Duration                                 : 2s 833ms
    Video
    Format                                   : JPEG
    Codec ID                                 : MJPG
    Duration                                 : 2s 833ms
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    El Heggunte can you Help me?
    I can not understand how have to do for transcode from my c0020.mxf into .mjpeg avi.
    With FFMPEG my NLE don't work.
    In mencoder is it possibile that? is it possibile with mjpeg tools?
    thank u
