Hi Everybody
I got Big Problems getting my m2ts File from BluRay (with VC-1 Codec) into MKV Container
I demuxed the vc-1 stream with tsmuxer and simply muxxed with mkvmerge back together (without any errors) but after that the mkv Video Playback is completly Jerky(Playback Looks like wrong Framerate to me)
on PC playback is Jerky too but when i activate "VC-1 timestamp correction " in LAV at once the Video Plays smooth
I don't know what i'm doing wrong it's the second Time i got this Problem...
How can i fix this? Please Help me.
Thank you all in advance![]()
Have you tried mux directly with mkvmergegui(without demuxing)? I think it supports m2ts.
yes, i ve tried with 6.2.0 directly from m2ts but still results in jerky playback
i also tried with virtualdubmod to save as mkv > but the same issue
^^yes Frame rate set correctly to 23,976 fps
i've tried virtualdubmod, mkvmerge 4.3.0 and 6.2.0 and when it Comes to mkv they all start stuttering
Video
ID :
4113 (0x1011)
Menu ID :
1 (0x1)
Format :
VC-1
Format profile :
Advanced@L3
Codec ID :
234
Duration :
2h 2mn
Bit rate :
29.5 Mbps
Width :
1 920 pixels
Height :
1 080 pixels
Display aspect ratio :
16:9
Frame rate :
23.976 fps
Color space :
YUV
Chroma subsampling :
4:2:0
Bit depth :
8 bits
Scan type :
Progressive
Compression mode :
Lossy
Bits/(Pixel*Frame) :
0.594
Stream size :
25.2 GiB (91%)
^^I'm a bit worried about that "Codec ID 234"
other vc-1 Show up like this:
Codec ID :V_MS/VFW/FOURCC / WVC1
tried now with eac3togui to mkv > same jerkyness
really annoying...
what else can i try to do?
the funny Thing is, if i demux with older Version of mkvextractgui i get a AVI file with VC1 codec which Plays just fine
but i want mkv
.M2TS to .MKV
By cjbrown80 in forum Video ConversionReplies: 2Last Post: 18th Aug 2011, 21:34 -
mkv or m2ts
By kcmccombs in forum Newbie / General discussionsReplies: 9Last Post: 21st Jul 2011, 04:25 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 11:26 -
M2TS to MKV
By mblanco2000 in forum Video ConversionReplies: 4Last Post: 11th Feb 2010, 13:27 -
QT to FLV results in jerky video
By zvikico in forum ffmpegX general discussionReplies: 7Last Post: 6th Jan 2009, 20:26
