Have just successfully extracted a PCM audio track from a BD disc. The format is this according to Mediainfo
What I want is to convert that audio track onto a file I can burn an audio CD with.Code:General Complete name : D:\Temp\Audio_3_English.W64 Format : Wave64 File size : 2.07 GiB Overall bit rate mode : Constant Audio ID : 0 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : 00001000-0000-0100-8000-00AA00389B71 Bit rate mode : Constant Bit rate : 4 608 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 96.0 KHz Bit depth : 24 bits Stream size : 1.00 Byte (0%)
The problem is I can't open the file with Soundforge 8.0, so I wonder:
1) If a later SF version would.
2) If I should proceed in a different way to extract the audio track and/or convert it.
Results 1 to 9 of 9
You'll have to convert the sampling to 44.1 KHz, the bit depth to 16 bits and the bit rate to the normal 1500 or so Kbps that audio CD uses.
Audacity can probably open it and convert it for you, but even at CD specs you may have more than will fit on one CD. I'm not sure. Just be prepared that this can happen. -
Oh, yes, I'm aware that I will have to downgrade all that you mention (sampling, bit depth, bit rate).
Will see how can I edit it so it fits in one CD, if possible. If not I will put it on two. -
Yes, Audacity did the conversion. Thanks.
I converted the file to one I could open with Soundforge, which I'm more familiar with. What's the bit rate for a CD? I still have 3072 kbps.
Audacity did the bit conversion to 16.
I have some issues with eac3to, but due to some incapacity of mine to use it. I need some proper how to instructions.Last edited by carlmart; 24th Sep 2013 at 08:48.
After downconverting, you shouldn't have any trouble getting the single file to fit onto a single CD: it's only ~62.5minutes, according to my calculation.
Should be able to just create a CUE file from within ImgBurn (using the downconverted WAV file). You could even add index points (aka "chapter" markers). Then burn away!
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 07:09 -
Dilema ? Problem when converting video with audio track
By doward in forum ffmpegX general discussionReplies: 5Last Post: 1st Dec 2010, 13:32 -
Converting two audio tracks to one stereo track in Sony Vegas?
By Great Googly Moogly in forum AudioReplies: 8Last Post: 12th Apr 2010, 02:49 -
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 04:31 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 22:54
